turn my cougar into a stick?is it possable? - TCCoA Forums
post #1 of 11 (permalink) Old 04-27-2004, 08:05 PM Thread Starter
hey i have plans to turn my 92 cougar into a stick. is it possable? it has a stock 5.0 H.O, i have heard rumers that the mdr2 trans out of a supercoupe will butt-up to a 5.0, i dont think it will. now if i go with a t-5 i have to worry about where the shifter comes out at so i might not be able to use a supercoupr console?? i have high hopes to do this in the future, could someone please help me thanks jason
shockwavef399 is offline
post #2 of 11 (permalink) Old 04-27-2004, 08:24 PM
the m5r2 trans will bolt up to the 50 .... the 3.8 and the 5.0 have the same bolt pattern ....
thumphed is offline
post #3 of 11 (permalink) Old 04-27-2004, 08:26 PM
PostSkank
StupidFly's Avatar
sure man, theres a bunch of information on that topic floating around the forums. And there is a few tech articles on it as well (get at those from the main page).
But as a quick rundown: the M5R2 will fit, you will need the related hardware from a 5-speed SC.
T-5 will also work, you will need the hardware (minus tranny) from the SC, you will need a bellhousing from a 5.0L M5R2 equipped F-150, and you will need to address the issue of moving the shifter farther back. So far there are 2 ways to pull that off, either fabricate and weld an extension box onto the transmission (look for the 5-speed swap article by papa john), or you can drop $400 bones on the MN12 Performance extension box.
There are more details to it than just that, but that is a quick over view for you. So just check out the tech articles, do a few of these: and you should be in good shape.
math > pasta
StupidFly is offline
post #4 of 11 (permalink) Old 05-03-2004, 11:29 PM
Ok... now what about a '95 cougar 4.6L??? I've seen manual conversion pics of 5.0s, but what about the 4.6L cougar?? I would love to have a 5 or 6 spd trans.
Clay
cman2007 is offline
post #5 of 11 (permalink) Old 05-04-2004, 12:35 AM
PostSkank
StupidFly's Avatar
the papajohn 5 speed swap article is done on a 4.6
Thunderbird I believe, but I cant see it being any different for the cougar
math > pasta
post #6 of 11 (permalink) Old 05-04-2004, 01:25 AM
Jimbobicus's Avatar
Send a message via AIM to Jimbobicus
I just put a T5 in my 93 Bird. I went with the MN12 Performance box, a large chunk of change but the shifter location is perfect.
Actually, the M5R2 bellhousing and transmission case are all one piece... if you are doing a M5R2 swap you will need the flywheel, clutch disk and pressure plate from a F-150... For the T5 swap any 86-93 Mustang T5 bellhousing will work.
To tell the truth, I really wanted to do a T56 6-spd swap, but that would have cost me over 3 grand... twice what the 5-speed swap did. For those who have the resources to do it, it can be done and it has been done. The 93-03 F-body (Camaro, Firebird) T56 has the shifter in the correct location for our cars and you can get a bellhousing from McLeod that will adapt to a 5.0 or a 4.6. The F-body T56 has an electronic speedometer built in. I didn't realize until I pulled my tranny that we have an electronic speedo also, it's just that it runs off a speedo gear in the transmission. I would assume that it would be possible to just tap into the signal coming from the T56 speedo. I haven't really looked into it, I'm just coming up with this as I go.... There are also several companies that make hydraulic clutch kits for the T56 as well. Remember Google is your friend!
Jimmy
1993 Thunderbird 5.0
Dual exhaust - no cats - Flowmaster 40 series mufflers
T5 - Aluminum flywheel - Stage II clutch
1990 Thunderbird SC
All stock... For now...
Jimbobicus is offline
post #7 of 11 (permalink) Old 05-04-2004, 01:32 AM
PostSkank
StupidFly's Avatar
good to know, so which flywheel is used for the M5R2?
math > pasta
post #8 of 11 (permalink) Old 05-12-2004, 12:00 PM
If you want a T5 to live in a heavy bird, you should consider the G-Force T5.
http://www.g-forcetransmissions.com/tran_gt-5.asp
The OEM T5 is marginal in a much lighter Mustang. In a heavier T-bird, it is subjected to higher TQ loads.
The only OEM T5 part that the G-Force uses, is the case. All the guts are new, heavier parts.
68COUGAR
68COUGAR is offline
post #9 of 11 (permalink) Old 05-12-2004, 08:03 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
Clay
you might want to get in contact with cobrarthunder. i know he has done the manual swap on his 4.6 tbird. just pm him or something
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #10 of 11 (permalink) Old 05-13-2004, 12:58 AM
I remember seeing an article on the 4.6L trans swap before but can't remember where I found it. It was a T-56 I think and had a homemade shifter linkage. I don't know if I'd like a 5spd in my heavy cougar though. I weighed it the other day and on a 1/4 tank fuel it weighed 3830lbs. I will try a stall TC and lower gears and see what I can accomplish with those before I get into a 5spd swap. I love driving manual cars its alot of fun.
Clay
cman2007 is offline
post #11 of 11 (permalink) Old 05-13-2004, 10:12 AM
The Great Obucina's Avatar
Clay
did you look in the tech articles section of the site?
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
