Another possible MLPS problem - TCCoA Forums
post #1 of 9 (permalink) Old 04-28-2004, 12:20 AM Thread Starter
Didn't want to hi-jack the other thread, so here it goes...
Just driving around in overdrive on the freeway, the trans jumps out of overdrive for about 2 seconds then back in. There dosen't seem to be any pattern to it. Some days it never does it, other days it will do it a few times in a few minutes. Also on the street when I''m off throttle it will drop from 3rd to 2nd, then back again.
I'm asking if this happened to you and what it was. I know there will be a few different causes from different people, I'd just like to hear it all.
Car info:
94 4.6
140K (trans rebuilt at 115K due to shudder)
Thanks!
PSI-Clone is offline
post #2 of 9 (permalink) Old 04-28-2004, 02:09 AM
kenshi's Avatar
Mine did it mainly in cold weather until I changed my MLPS.
1994 Thunderbird LX 232
Discarded air silencer. Gutted cats. [email protected] mph at this point. 8.8" Trackloc differential with polyurethane bushings. PA manual valvebody. Sport springs.
1989 Thunderbird SC 5-speed
ESM ported supercharger. Performance exhaust.
2005 Yamaha YZF600R
kenshi is offline
post #3 of 9 (permalink) Old 04-28-2004, 02:14 AM
Question
So do you want to fix this problem or just compare notes.
Chris.................
ChrisW01 is offline
post #4 of 9 (permalink) Old 04-28-2004, 04:20 AM
i would say that sounds like MLPS problems to me. I picked one up for 40$ i believe from bulkpart.com and had it installed in no time. Just make sure your reverse lights come on after you install it, if not loosen the bolts some and move it until the lights come on, then tighten it down.
Green95LX is offline
post #5 of 9 (permalink) Old 04-28-2004, 03:28 PM Thread Starter
Well, I had ford send me a MLPS to my shop today. I'll install it later on when I'm not busy. It was $64 (not bad for original ford and no wait time) and hopefully this will cure what ails me, er... the trans.
post #6 of 9 (permalink) Old 04-28-2004, 05:11 PM
kenshi's Avatar
Okay, maybe I should have been more blatantly obvious. Since my MLPS caused those same symptoms, there's a possibility that his is too. Sorry for any confusion I caused by not pointing out that link.
2005 Yamaha YZF600R
kenshi is offline
post #7 of 9 (permalink) Old 04-28-2004, 10:23 PM
NAPA sells the MLPS for $19.95 and it's made in USA. Just my .02
They call it the neutral safety switch.
chunk is offline
post #8 of 9 (permalink) Old 04-28-2004, 10:38 PM Thread Starter
Yeah, but the distributor I bought from NAPA had to be returned twice. For a little more I got a real ford part and no hassle... Now as for everything else I attach to the engine, thats another story.
post #9 of 9 (permalink) Old 04-29-2004, 01:07 PM
Bulkpart.com slapped a Ford MLPS on my doorstep for 40$
