Frpp gears question - TCCoA Forums
post #1 of 9 (permalink) Old 04-29-2004, 01:06 AM Thread Starter
Tinfoil hat wearer
azreael344's Avatar
Send a message via AIM to azreael344 Send a message via Yahoo to azreael344
Frpp gears question
Ok I got my 3.73 FRPP gears off ebay today. First of all the Pinion gear has 2 teeth chipped in the back of the gear. Yeah I'm not so happy about that. And we didn't notice till we already installed the ring gear.
But anyway here is the quesion. I've never seen a ford ring gear that was not completely flat on the back side. I meen it mounts flush to the carrier but the outter edge is slopped up. I wish i could post pics of what i'm talking about. Does any body think these are Knock offs. They came in a Ford box and all
1996 Laser red 4.6 V8.
Flowmaster catback, PI Intake, PI cams K&N 9 inch cone filter 80mm LMAF, Trickflow plenum, 75mm BBk throttle body,SCT Chip, Red FRPP wires, 22c plugs & 180* t-stat, PBR calipers, ASP underdrives. Marauder torque converter, FRPP 3.73 gears, Custom Drive shaft, Eibach Springs, Tokico shocks, JMOD, B&M 24k Tranny Cooler, Clear corners, 145mph Speedo,17X9 Cobra R's, Complete SC interior including SC Handbrake conversion
Best time [email protected] 93.18 MPH 4/16/2004
My other ride: 2001 F150 4x4
Aol screen name: Azreael344
azreael344 is offline
post #2 of 9 (permalink) Old 04-29-2004, 01:13 AM
Sweet T
SanDiegoLXBird's Avatar
So you're saying the pinion gear is chipped and the ring gear is warped?
1994 SC 5-Speed
SanDiegoLXBird is offline
post #3 of 9 (permalink) Old 04-29-2004, 01:20 AM Thread Starter
Tinfoil hat wearer
azreael344's Avatar
Right that the pinion gear is chipped. The ring gear is not warped that i can tell. Like I said the ring gear sits flush. its hard to explain without pics. Hopefully somebody will understand. Every other ford gear i have seen from the the back side of the gear if like stitting on a table is angles up at a constant from the back of the gear.its at a constant. this set of gears here has twt differten angles as it's going to the top of the gear
post #4 of 9 (permalink) Old 05-06-2004, 03:20 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
The ford gears more than likely have ford logos on them and motorsport part numbers. I know for sure mine read "3.73" some other wierd numbers and I think there was a ford logo, but I had 3 sets of gears in front of me at the time, I can't really remember for sure. As for this sloping...man you have at least me confused!
-Rob
-Rob
Rob is offline
post #5 of 9 (permalink) Old 05-06-2004, 02:08 PM
Silver95Bird's Avatar
The Ford ones will have the appropriate markings on them... but pics would help us greatly here.
Silver95Bird is offline
post #6 of 9 (permalink) Old 05-06-2004, 02:13 PM
jk69cat's Avatar
theres a reason i wont buy used gears, and you hit it on head! i dont like guessing about unknown damage and even that small chip will cause a fracture eventually.
mn12 less!
jk69cat is offline
post #7 of 9 (permalink) Old 05-06-2004, 06:55 PM
Trumpeter Extraordinaire
IronChopz's Avatar
From the 2004 FRPP catalog, regarding the 3.73 gears:
Part # M-4209-F373N "Replaces our popular M-4209-F373. New manufacturing technology utilizing a Face Hob Process which features a single pass pinion tooth machining operation compared to a conventional three pass process for machining. CNC cut and lapped gear teeth. Higher strength and better quality gears are produced with the Face Hob Process. Note: these new gears look a little different, the gear teeth are cut on a different angle and the ring gear has a bevel on the back of the gear."
Check the part number of the gears you received. You may have a set of the new ones....
Edit corrected typographical error.
IronChopz is offline
post #8 of 9 (permalink) Old 05-07-2004, 12:58 AM Thread Starter
Tinfoil hat wearer
azreael344's Avatar
Part # M-4209-F373N "Replaces our popular M-4209-F373. New manufacturing technology utilizing a Face Hob Process which features a single pass pinion tooth machining operation compared to a conventional three pass process for machining. CNC cut and lapped gear teeth. Higher strength and better quality gears are produced with the Face Hob Process. Note: these new gears look a little different., the gear teeth are cut on a different angle and the ring gear has a bevel on the back of the gear."
Dude you were right thanks. I knew they looked different. I figured somebody eventually would figure out what i meant.
jk89cat theres a reason i wont buy used gears, and you hit it on head! i dont like guessing about unknown damage and even that small chip will cause a fracture eventually
I wouln't buy used gears either. It's not a good idea
post #9 of 9 (permalink) Old 05-07-2004, 01:00 AM
Rob
Rob's Avatar
It's definitely not a good idea, but I did it anyway . My FRPP 3.73s cost me $50
-Rob
-Rob
Rob is offline
