Who can't leave the O/D button alone? - TCCoA Forums
View Poll Results: Who can't leave the O/D button alone?
always pushing button 39 48.75%
rarely push button 21 26.25%
only turn on O/D on highway 12 15.00%
what button? 8 10.00%
Voters: 80. You may not vote on this poll
post #1 of 27 (permalink) Old 05-06-2004, 02:05 AM Thread Starter
I was wondering who uses overdrive (O/D) when driving around town (speeds under 55). I am always flipping the O/D button depending where I am driving. Does it cause wear to the trans. if the O/D is disabled for extended times. At constant highway speeds I always enable the O/D.
W.Cup is offline
post #2 of 27 (permalink) Old 05-06-2004, 02:31 AM
I think the ford manual says to lockout OD at speeds under 40mph or city driving. I usually just leave it engaged since it helps gas mileage out. i do press the button sometimes though, or friends will feel the button on the shifter and press it to see if it causes a light to come on.
Green95LX is offline
post #3 of 27 (permalink) Old 05-06-2004, 02:38 AM
Refrigerator Raider Hater
GreenBird's Avatar
I leave it off unless I am going to be doing at least 50mph for an extended period of time, so when I do have it on, it'll usually stay in OD for quite awhile.
The shift is what causes wear, not staying in or staying out of OD.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 27 (permalink) Old 05-06-2004, 03:39 AM
kenshi's Avatar
Hmm... I need to remember all that. I sometimes play with mine, but not a lot. My friend used to would turn off my overdrive every time I was out of the car or not looking at the dash or shifter. He got me a time or two, but it's pretty hard to miss that super luminescent light.
1994 Thunderbird LX 232
Discarded air silencer. Gutted cats. [email protected] mph at this point. 8.8" Trackloc differential with polyurethane bushings. PA manual valvebody. Sport springs.
1989 Thunderbird SC 5-speed
ESM ported supercharger. Performance exhaust.
2005 Yamaha YZF600R
kenshi is offline
post #5 of 27 (permalink) Old 05-06-2004, 06:47 AM
I ALWAYS lock out my OD at any speed below 70 mph. Mainly for the reason that I haven't been able to isolate the problem of the transmission slipping out of gear with light load and speeds below 70 (I have 3.08's so the rpms are around 2K)
Even on the interstate, if I'm around 70 mph and headed up a long hill, I'll pop it out of OD.
Now it's just a habit. I even do the same thing in my Mark (for absolutely no justifiable reason).
69 F100 LWB w/460 Engine
post #6 of 27 (permalink) Old 05-06-2004, 08:22 AM
4 Cam Bird's Avatar
Its habit now, get in the car turn it on, turn off the O/D. I only use it on the highway or interstate, never in town. I even do it in the truck now without even thinking about it.
2011 CTS-V Wagon
4 Cam Bird is offline
post #7 of 27 (permalink) Old 05-06-2004, 08:44 AM
Since I have a custom tune, my normal driving shifts are a bit higher. Doesn't even think about OD until 40-45 mph. I get the TC shudder at that point...
Grasshopper is offline
post #8 of 27 (permalink) Old 05-06-2004, 09:32 AM
I do the same thing in my bird. I also turn off the traction control unless it wet out. I just wish the bright a** green OD light wasn't so bright, or located somewhere else. I hate having people ask me "Hey, why's that light on in the dash? What's wrong w/ your car?" I guess they think its a CEL. Morons.
FordMan77 is offline
post #9 of 27 (permalink) Old 05-06-2004, 10:29 AM
4 Cam Bird's Avatar
I'd forget to turn it on on the highway if not for that light. I'm see myself driving a very long distance with it off at some point in the truck. The light is in the end of the shifter and my hand position blocks it from sight.
2011 CTS-V Wagon
post #10 of 27 (permalink) Old 05-06-2004, 11:39 AM
Astrophysicist / PostWhore
66dvlbrd68's Avatar
I leave it off in town. I turn it on when I hit the freeway and am not in "spirited driving" mode (which is hardly ever nowadays).
At least that is how I used to drive. My friend took my OD button out of the shifter handle, and now it is installed incorrectly. Now I cannot lock it out at all.
Mike | RSW | THP | MF | SRTConnection |
1996 Ford Thunderbird LX V8 + 1992 Ford Mustang hatchback + 1989 Ford Mustang notchback = no where else to park at my house!
66dvlbrd68 is offline
post #11 of 27 (permalink) Old 05-06-2004, 11:47 AM
4 Cam Bird's Avatar
That little metal thing is a PITA to get back in there right when you take the button out. Its not hard to fix, pull the button out and do it. Sometimes it just takes a couple trys to get the metal thing lined up.
2011 CTS-V Wagon
post #12 of 27 (permalink) Old 05-06-2004, 01:10 PM
Trumpeter Extraordinaire
IronChopz's Avatar
A fifth category, splitting the difference between Always Pushing Button, and Rarely Pushing Button, is needed....
.....that way, I can submit an accurate vote, based on how I use it!
IronChopz is offline
post #13 of 27 (permalink) Old 05-06-2004, 01:14 PM
jk69cat's Avatar
my bird and cat dont have it, but my f150 does .i only turn it off when im towing or offroad with it.
mn12 less!
jk69cat is offline
post #14 of 27 (permalink) Old 05-06-2004, 07:00 PM
I use it to shift into 3rd to slow the car down when that corner is coming up, sometimes into 2nd. Does this hurt the trans? Seeing as how it is touchy to begin with. I know that power shifting can't be good either.
SVT Sleeper is offline
post #15 of 27 (permalink) Old 05-06-2004, 07:47 PM
Traveler's Avatar
I just leave it alone. I won't go into overdrive below about 40 45 mph anyway. Never gives me any problem. The manual says to leave it alone unless you are towing, or in mountainous terrain. i think.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #16 of 27 (permalink) Old 05-06-2004, 10:01 PM
I always turn mine off unless i'm on the freeway. Otherwise, the trans flips out and shakes like crazy whenever i downshift. It goes into OD whenever i'm not on the throttle, pretty much. And then it'll hesitate for a second or so before it upshifts. I'm not exactly sure what the problem is, but I'd be willing to bet that at least part of the blame is on the TC. Oh, well. Getting a Marauder TC within a few months anyway
SloMo228 is offline
post #17 of 27 (permalink) Old 05-06-2004, 10:40 PM
I am confused by everyone's responses.. So let me get this straight:
O/D is used by most of you all on the highway only
and you turn O/D off around town..
Wouldn't you use up more gas with the O/D off? I like driving my car A LOT more with the O/D off because to me it sounds a lot more healthier, but I don't because I was always taught that higher MPG comes out of using O/D everywhere..
1997T-Bird is offline
post #18 of 27 (permalink) Old 05-08-2004, 08:19 AM
Johnny Bling Bling
93 lx's Avatar
i voted "what button" as i have an aod. i do run around in D 98% of the time though, not OD. i drive a lot in 2nd too.....cause it's fun, and i can!!! LOL
2009 Ford Flex Limited AWD
93 lx is offline
post #19 of 27 (permalink) Old 05-08-2004, 01:56 PM
miller1995's Avatar
Wish my button worked. Broke the wires while i was replacing the main button and haven't gotten around to fixing them yet. Its been almost a year now but it took me a while to find the button after buying my car anyway so I hadn't really been used to using it anyways.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #20 of 27 (permalink) Old 05-08-2004, 05:40 PM
I've driven most of the last 5 or six years at speeds under 45 mph (I live on an AF base with a 35mph max speed limit). I mostly drive to and from work and on side streets near home. I rarely hit the highway w/ my bird, maybe only once or twice a month and I have out of habit just left the trans in OD. Does anyone know of anything negative that could happen to the tranny from driving in OD at low speeds on a regular basis? (I started getting the typical T-bird tranny shudder about a year ago)
TX T-Bird is offline
post #21 of 27 (permalink) Old 05-08-2004, 08:29 PM
5w30 Guzzler
chilipepprflea's Avatar
Send a message via AIM to chilipepprflea
I do the same. I asked the same question a while back and got the response that there shouldn't be anything wrong with it.
chilipepprflea is offline
post #22 of 27 (permalink) Old 05-08-2004, 11:23 PM
kenshi's Avatar
Jerry's tranny guide recommends against downshifting to second a lot. Doesn't say anything about downshifting to third. I got my manual valvebody in two days ago, so I've been doing it a lot. I love engine braking.
2005 Yamaha YZF600R
kenshi is offline
post #23 of 27 (permalink) Old 05-09-2004, 11:03 AM
TCCoA Founder
Sir William's Avatar
I know it's recommended not to do the 4->2 downshift. If you have to pass somebody on the highway, shift out of overdrive and let it shift before you punch it. So that if it downshifts, it's not detrimental to the tranny. Then once you're around, you can turn O/D back on.
You don't want to spend tons of time in 1st or 2nd though as the planetaries will build up heat pretty quickly. You don't want them too hot.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #24 of 27 (permalink) Old 05-09-2004, 10:16 PM
Thank god I always did it like that...
That still makes me wnoder why people use D in town and not O/D.. Does it save gas any?
post #25 of 27 (permalink) Old 05-10-2004, 04:26 AM
kenshi's Avatar
Because at low speeds, the car shifts in and out of overdrive a lot, and that can wear out the overdrive band. I saw my overdrive band when I installed my valve body and I think I'll start heeding that advice myself.
2005 Yamaha YZF600R
kenshi is offline
post #26 of 27 (permalink) Old 05-16-2004, 07:45 PM
jturmel's Avatar
I live in the suburbs where we have mile stretches with not much traffic between lights and I'll leave OD on then so that it is in 4th for those stretches then if I start hitting some traffic I'll make sure it's off.
-J
1991 Sport 5.0
RIP 1991-2006
jturmel is offline
post #27 of 27 (permalink) Old 05-17-2004, 08:25 PM
I use the button all the time.
First, lots of hills here and in slow traffic I delay OD engagement until I am past the point of hunting gears.
I also prepare for traffic with it. Often you need to be able to move easy but firmly without a harsh downshift.
Engine braking is the other time. In OD I don't get the same braking as 3rd, so in certain instances I just downshift for a few seconds then reengage and cruise along.
The rumble sound from deceleration also is a warning to those who would ignore my presence.
Now if I could get an autostick retrofit designed and ready to roll, we'd all have a little more fun.
rm
RichardM is offline
