TC upgrades for 3.8? - TCCoA Forums
post #1 of 20 (permalink) Old 05-06-2004, 09:16 AM Thread Starter
super6ter's Avatar
I am looking for something better than stock. I wanted to get a MarkVIII TC but I can't find anything saying if it will work or not. Just need some info. on what may work or not. Thanks.
super6ter is offline
post #2 of 20 (permalink) Old 05-06-2004, 04:11 PM
Don't take my word on it, But i have heard that the MK8 and Maruauder TC's will work on our cars if we use the MK8 Flexplate.
Green95LX is offline
post #3 of 20 (permalink) Old 05-06-2004, 10:01 PM
Fry Rice Specialist
Casper's Avatar
it will.
CarDomain Page
Casper is offline
post #4 of 20 (permalink) Old 05-07-2004, 09:21 AM
Astrophysicist / PostWhore
66dvlbrd68's Avatar
A Marauder converter will bolt up to a 3.8L?
If so, that would probably be a heck of an upgrade, as the stall is nice for the price.
Mike | RSW | THP | MF | SRTConnection |
1996 Ford Thunderbird LX V8 + 1992 Ford Mustang hatchback + 1989 Ford Mustang notchback = no where else to park at my house!
66dvlbrd68 is offline
post #5 of 20 (permalink) Old 05-08-2004, 12:58 AM
Fry Rice Specialist
Casper's Avatar
only on 3.8 with the 4r70w and also mark 8 flexplate.
CarDomain Page
Casper is offline
post #6 of 20 (permalink) Old 05-09-2004, 05:11 PM
get a converter for a Stock 99+ mustang V6 converter they stall at ~2200rpm instead of ~1800rpm like the stock unit.
rancherlee is offline
post #7 of 20 (permalink) Old 05-11-2004, 04:53 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
Or on an AOD with the wide ratio gear set (aftermarket) as it has the 4r70w input shaft.
Thomas is offline
post #8 of 20 (permalink) Old 05-12-2004, 02:54 AM
I'd rather have a Marauder TC for the time and money it's going to take to put one in, it's not worth it to buy a 99 V6 Mustang TC, the marauder TC is a very good deal for the money you spend on one.
post #9 of 20 (permalink) Old 05-12-2004, 06:53 AM
PCD
Confirmed V6 Nut
Green95LX,
Mind expanding your answer?
I am contemplating an upgrade to my TC. In the Tech articles it was mentioned the right match of TC can drop your 1/4 time by up to a second.
I'm not looking for a food fight here. Let's look at the numbers and then the reasoning for each choice.
I've got one additional question. What is there in the way of aftermarket TC for street and strip applicable to the 3.8L?
PCD is offline
post #10 of 20 (permalink) Old 05-12-2004, 08:08 AM
Uber Luber
Thomas's Avatar
mark viii tc = 2200-2600rpm stall
marauder tc = 2600-3000rpm stall
PI stallion converter = 3200-3500 rpm stall (or more dunno)
marauder tc is best for a cheap choice. But if you're serious about going fast with a 4r70w tranny, then get a pi stallion converter for 3200rpm.
-Thomas
Thomas is offline
post #11 of 20 (permalink) Old 05-12-2004, 01:42 PM Thread Starter
super6ter's Avatar
With any of these upgraded TC's is a new input shaft or anything else really needed besides the flexplate.(have a trans cooler and temp gauge) Also I was looking at 3:73 trakloc.
With these two upgrades should I see a good improvement in acceleration?
2001 Ford F-150 Supercrew 4x4
1994 Toyota Pickup 4x4
Cam, Header, 36x12.50's
email: [email protected]
post #12 of 20 (permalink) Old 05-12-2004, 01:48 PM
PCD
Confirmed V6 Nut
Thomas,
Is the 99 Mustang TC the same as...?
If it's different, where would it fit in the list you posted for stall range?
PCD is offline
post #13 of 20 (permalink) Old 05-12-2004, 02:16 PM
Uber Luber
Thomas's Avatar
the 99 v6 converter is the same as yours. the 99 GT converter is the same as the mark's.
Thomas is offline
post #14 of 20 (permalink) Old 05-12-2004, 03:30 PM
I agree with thomas here, if you're looking for a budget converter. The Marauder TC is the best value. If you're seriously into racing then look into a PI Stallion converter or a Morris converter, Which is what JL uses if i'm not mistaken.
post #15 of 20 (permalink) Old 05-12-2004, 04:16 PM
Jedi Master
mn12xr7's Avatar
agreed, maruader tc all the way with mark viii flex plate
along with the j-mod , a nice tranny cooler, 93 mark viii one piece aluminum ds and chip and you'll have a killer set up
all parts are from 150-320 price range
-Orlando
mn12xr7 is offline
post #16 of 20 (permalink) Old 05-12-2004, 04:19 PM
Traveler's Avatar
Whats the stall on a 99 v-6 Mustang TC compared to a 97 V-6 T-bird?
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #17 of 20 (permalink) Old 05-12-2004, 05:38 PM
Probably like 1800rpm for both of them.
post #18 of 20 (permalink) Old 05-12-2004, 07:22 PM
Uber Luber
Thomas's Avatar
correct
Thomas is offline
post #19 of 20 (permalink) Old 05-13-2004, 05:34 AM
PCD
Confirmed V6 Nut
Thomas,
You used a range of stall speeds for the converters. Are they adjustable before installation or that's they way they work?
PCD is offline
post #20 of 20 (permalink) Old 05-13-2004, 04:07 PM
Uber Luber
Thomas's Avatar
depending on the amount of torque you make will depend on the stall the converter engages at.
Thomas is offline
