8.8 gear compatability - TCCoA Forums
post #1 of 7 (permalink) Old 05-08-2004, 09:09 AM Thread Starter
Awaiting E-Mail Confirmation
tinman_72's Avatar
Are all 8.8 ring and pinion gears interchangable? I can take 3.73 gears out of any 8.8 rear end and put them in the T-bird IRS right?
tinman_72 is offline
post #2 of 7 (permalink) Old 05-08-2004, 11:13 AM
5.0 Chero's Avatar
yes as far as gears go 8.8 is 8.8!
THE PYL !
91 Tbird lx 5.0 swap
GONE 93 5.0 Stang vert
86 F250 Diesel 4x4
GONE 89 Aerostar
2003 F350 Super duty
1996 Exploder
5.0 Chero is offline
post #3 of 7 (permalink) Old 05-08-2004, 09:51 PM Thread Starter
tinman_72's Avatar
I was just making sure. Someone told me before that the pinion shaft was longer on the IRS setup. I didn't fully believe him, but I wanted to make sure before I spent any money.
post #4 of 7 (permalink) Old 05-08-2004, 11:25 PM
kenshi's Avatar
I thought spline count was important, like ours have 28 splines and Mustangs have 31.
1994 Thunderbird LX 232
Discarded air silencer. Gutted cats. [email protected] mph at this point. 8.8" Trackloc differential with polyurethane bushings. PA manual valvebody. Sport springs.
1989 Thunderbird SC 5-speed
ESM ported supercharger. Performance exhaust.
2005 Yamaha YZF600R
kenshi is offline
post #5 of 7 (permalink) Old 05-09-2004, 01:35 AM
Tinfoil hat wearer
azreael344's Avatar
Send a message via AIM to azreael344 Send a message via Yahoo to azreael344
The splines for the the halfshafts are in the carrier not the ring and pinion
1996 Laser red 4.6 V8.
Flowmaster catback, PI Intake, PI cams K&N 9 inch cone filter 80mm LMAF, Trickflow plenum, 75mm BBk throttle body,SCT Chip, Red FRPP wires, 22c plugs & 180* t-stat, PBR calipers, ASP underdrives. Marauder torque converter, FRPP 3.73 gears, Custom Drive shaft, Eibach Springs, Tokico shocks, JMOD, B&M 24k Tranny Cooler, Clear corners, 145mph Speedo,17X9 Cobra R's, Complete SC interior including SC Handbrake conversion
Best time [email protected] 93.18 MPH 4/16/2004
My other ride: 2001 F150 4x4
Aol screen name: Azreael344
azreael344 is offline
post #6 of 7 (permalink) Old 05-13-2004, 01:04 AM
What if I was to get a Trac-Lok rear end or whatever the limited slip rear-end in the '99+ cobra's, would it have the same spline as the t-bird/cougars?
Clay
cman2007 is offline
post #7 of 7 (permalink) Old 05-13-2004, 02:37 AM
No, only the 99's have 28 spline, after 99 they went to 31 spline.
Green95LX is offline
