mn12performane irs pinion brace - TCCoA Forums
post #1 of 16 (permalink) Old 05-12-2004, 01:02 AM Thread Starter
Fry Rice Specialist
Casper's Avatar
any body have buy it and any input on it?
CarDomain Page
Casper is offline
post #2 of 16 (permalink) Old 05-12-2004, 10:33 AM
I have one of the first IRS Pinion Braces installed on my car.
First I must commend Rich for all the time he spend developing the brace. The Fit was SUPURB!!!!!! Every contour matched my car PERFECTLY!!!!!!
Some installation notes. If you want to install the brace with the exhaust & gas tank still on the car (like I did), you can Not use a socket on the lower control arm nut. The lower control arm nut is 1 5/8". I bought a set of huge BOX END wrenches from Harbor Freight ($40). You will want to soak nut, bolt, & bushings several times with PB Blaster, & let it sit for at least a day. You'll be Thankful you did!!!!!! I had the car on ramps for the install. To break the nut loose (160 - 240 ft/lbs!!!!) I braced my back against the opposite wheel & ramp, and pushed on the box end wrench with my feet.
Once the huge nut is off, tap the bolt back, until only about 1/16" of it is sticking out from the frame. Don't tap it all the way through the bracket, because the diff. will sag from lack of support. It's a real PITA getting everything to line back up. BTDT!!!!! I used a box end wrench on the head of the lower control arm bolt, to ensure that the bolt didn't turn with the nut. It wasn't necessary though, due to the liberal dousing with BP Blaster for 2 days.
I HIGHLY RECOMMEND that you install the Poly diff. bushings along with the brace. If you Need the brace, then you need poly bushings too!!!!!! I also have (& HIGHLY RECOMMEND) the poly rear diff. mount that Wynn (tbird88) makes & sells. I do not have Any increase in noise or vibration with either of the poly mounts or the IRS brace.
You can get an OPEN END wrench on the top of the front diff. mount bolt. You feed the wrench up between the gas tank & diff. Then hold the wrench with your other hand, up around the Back of the diff. My front diff. mount bolt did not move at all when I loosened up the bottom nut, but I had the wrench on to top nut, just in case it did.
The one thing I had to modify, was the heat sheild on the bottom of the gas tank, passenger side. Mine was pretty badly bent up, & I had to use some tin snips to cut a small portion of the it off. This in No way reflects on the IRS brace!!!!
Now about controlling HWH. The IRS Pinion Brace made a HUGE difference in reducing HWH!!!!!!! Enough of a difference, to make the price of it, insignificant compared to the improvement it deliveres. I haven't tested it at the Martin Dragway yet, but on the street, it eliminated about 80% of my HWH. Once again, I also have the poly front diff. bushings & Poly rear mount. If you still have OEM rubber mounts, your HWH may not be reduced as much as mine was.
My HWH was so bad ( modded '89 5-spd) that on the strip, in the past I've always had to pedal the car in 1st. gear to control the hop, & hopped it pretty bad on the 1 - 2 shift. I even hopped the 2 - 3 shift most times.
I see that you're from Midland. I'm from Buchanan (SW MI.), but spend quite a bit of time at my parents place in Martin. They live close enough to the drag strip, that we can hear the loud speakers clearly. Midland isn't that far from Martin, We should get together sometime! I'd like to see an SC mini-meet in our area this summer.
68COUGAR
68COUGAR is offline
post #3 of 16 (permalink) Old 05-12-2004, 11:18 AM
Jedi Master
mn12xr7's Avatar
i want one!!!
so it did reduce wheelhop???
-Orlando
mn12xr7 is offline
post #4 of 16 (permalink) Old 05-12-2004, 11:25 AM
Eleventeenth Gear Poster
Aaron K.'s Avatar
Originally posted by mn12xr7
i want one!!!
HWH = Horrible Wheelhop
Sold = 96 Thunderbird
Aaron K. is offline
post #5 of 16 (permalink) Old 05-12-2004, 11:34 AM
Jedi Master
mn12xr7's Avatar
thanx for the clarification
-Orlando
mn12xr7 is offline
post #6 of 16 (permalink) Old 05-12-2004, 11:41 AM
HWH
In my case HWH = Horrendous Wheel Hop!!!!!!!!
& YES it DID cure about 80% of my HWH on the street.
Haven't tested it at the strip yet, due to blowing out my heater core. I now have "Lake Anti-Freeze" (similiar in size, to Lake Michigan, only not as clean) in the pass. front of my car.
68COUGAR
68COUGAR is offline
post #7 of 16 (permalink) Old 05-12-2004, 11:49 AM
96bird's Avatar
If you want to cure wheel hop gets some slicks.... I do think the pinion brace is a good idea though.
Russell
96bird is offline
post #8 of 16 (permalink) Old 05-13-2004, 01:53 PM Thread Starter
Fry Rice Specialist
Casper's Avatar
i'm looking into one is because i'm planning on the poly pumpkin bushing also and since i will do the rear might as well get that bar as well. i have also have tranny crossmember mount waiting to be install and waiting for jl's rltb and rsb. this is because i notice some play in the drivetrain area and like to cure it before breaks up anything.
i would like to have a meet also.
CarDomain Page
Casper is offline
post #9 of 16 (permalink) Old 05-13-2004, 02:18 PM
Rear Sway Bar vs. HWH
I have the 1 3/8" bars on my car. They are GREAT, they make the car corner like it's on rails. Don't be afraid of the big bars.
Also don't be mislead into thinking that a larger sway bar will help with HWH! Big R. Sway bars only control wheel hop in SOLID AXLE cars, NOT IRS cars. I have both, with large R. Sway bars.
68COUGAR
68COUGAR is offline
post #10 of 16 (permalink) Old 05-14-2004, 07:14 AM
Not to knock Rich, he's a great guy and bought just about every poly bushing he sells , but $235 seems a bit steep compared to the ones available for the mustangs. Which are from $40 - $60. The only difference is i believe ours is longer (haven't compared), but I crawled under my car took measurements, drew it up in AutoCAD, and am going to weld my own. For $60, sure id buy one, for $235, I will make my own.
Fusion0507 is offline
post #11 of 16 (permalink) Old 05-14-2004, 06:17 PM
It's not just the length that's different.
Where did you find a Mustang IRS Pinion brace for $40?
Curious 68COUGAR
68COUGAR is offline
post #12 of 16 (permalink) Old 05-14-2004, 11:39 PM Thread Starter
Fry Rice Specialist
Casper's Avatar
sometimes in my opinion some of the stuff is you get what you pay for. not every person have the equipment needed to fabricated stuff nor even knowledge or time. i know it is expensive but, do i have a choices? equipment to make one, no! time to make one, no! cash to buy one, yes.
not many people are making stuff for our cars anymore and rich still doing it, might as well give him little bit support so he will continue to r&d stuff for our cars.
anybody want to correct me?
CarDomain Page
Casper is offline
post #13 of 16 (permalink) Old 05-15-2004, 02:02 AM
It seems I was mistaken. (I could have sworn I saw one somewhere a while back for ~60 but it quite possibly someone selling one used on a forum) Heres one for $143:
http://www.mustanggiant.com/052769600004.html
http://store3.yimg.com/I/mustanggiant_1781_6842452
The one from Steeda.com is $100 (no page link).
MN12performance Brace (for reference):
http://forums.tccoa.com/showthread.p...s+pinion+brace
Again, like I said, Im not saying anything bad about Rich. He was great to deal with, answered all my questions, and shipped out the next day. Id do business with him again no question. He deserves to be compensated for his time and effort. That is not in question. But, I have the time and access to the equipment, so I can make myself one and send it to be powdercoated.
post #14 of 16 (permalink) Old 05-15-2004, 11:45 AM Thread Starter
Fry Rice Specialist
Casper's Avatar
and one thing i like rich brace is that his got extra support point than the other one.
and here i couldn't find a powdercoater shop.
CarDomain Page
Casper is offline
post #15 of 16 (permalink) Old 05-17-2004, 01:21 PM
? They both have 4 points that they tie together.
post #16 of 16 (permalink) Old 05-17-2004, 02:02 PM Thread Starter
Fry Rice Specialist
Casper's Avatar
i mean the one that comes down 90 degree triangle support.
CarDomain Page
Casper is offline
