RPM in OD - TCCoA Forums
post #1 of 8 (permalink) Old 05-12-2004, 08:21 PM Thread Starter
RPM in OD
ok, I got my LS project going again. Just took and new Fuel Pump and lots of scrubbing.
The TV cable was stock in the engaged postion from sitting, so it wasn't shifting worth a crap. A little lube and she shifts smooth again. One thing I did notice is that is seem to have a high RPMs in OD. It seems to run at 3000 @ 70 mph. It has a Stock AOD for a 90 LS, and had sit for over 4 years.
Any Ideas? It seems to shift smooth. When the tranny in my LX went, it shifted like crap.
Thunder139 is offline
post #2 of 8 (permalink) Old 05-12-2004, 10:36 PM
kenshi's Avatar
Are you sure it's going to overdrive? Mine is at around that rpm at 70 in third gear. I assume it has stock gears.
1994 Thunderbird LX 232
Discarded air silencer. Gutted cats. [email protected] mph at this point. 8.8" Trackloc differential with polyurethane bushings. PA manual valvebody. Sport springs.
1989 Thunderbird SC 5-speed
ESM ported supercharger. Performance exhaust.
2005 Yamaha YZF600R
kenshi is offline
post #3 of 8 (permalink) Old 05-16-2004, 07:08 PM Thread Starter
Ok,
I had some time to git it out on the open road. It does shift, but extremly late. I'm talknig around 4500 RPM. Once it shifts it seems to do just fine. Sits around 2000 at 70 mph
Shawn
post #4 of 8 (permalink) Old 05-16-2004, 11:54 PM
Silver95Bird's Avatar
Sounds like the TV cable needs to be adjusted.
Silver95Bird is offline
post #5 of 8 (permalink) Old 05-17-2004, 05:40 PM Thread Starter
Ok, being the novice that i am, how do you adjust the TV cable to where it needs to be? I know i don't want to drive it more than i have to with that messed up.
Shawn
post #6 of 8 (permalink) Old 05-17-2004, 11:50 PM
I'm not an expert on SC's but I know there's a tech article about that on here... that would probably be more helpful.
post #7 of 8 (permalink) Old 05-18-2004, 08:09 AM Thread Starter
This isn't on my SC, This is on my NA 90 Cougar LS
post #8 of 8 (permalink) Old 05-19-2004, 02:48 PM
PCD
Confirmed V6 Nut
Same difference. Read the tech article or visit a real tranny shop, unless you got a practiced TCCoA buddy near by.
PCD is offline
