Mark VIII TC install finished! - TCCoA Forums
post #1 of 5 (permalink) Old 05-17-2004, 07:26 AM Thread Starter
Talking Mark VIII TC install finished!
Hey guys,
I finally finished (with the help of my dad) the install on Saturday. Thanks everyone for your help and advice. It took longer than expected (4 days total) due to getting stuck and taking breaks in between. Anyway, the car no longer shudders and it does feel more responsive, although I haven't really driven it hard yet (is there a break in period for remanufactured TC's?).
Here's my experience with the install. This was my first time dropping the tranny, so it's doable for newbie's, but I did need an extra hand and there were periods when I wasn't sure I would finish. Here's what I found to be the most difficult parts. The two bellhousing bolts on top were the hardest to remove. I found a ratching wrench invaluable for those. Also, it is very easy to not have the TC set all the way in the bellhousing. The first time, I thought it was set only to find out it wasn't when the crank would not turn after bolting up the bellhousing. An easy way to check is to place the lower torque converter cover over the lower bellhousing (prior to bolting up the bellhousing) and seeing if the TC still turns. If the nuts do not clear the cover, than the TC is not set. Also, if you have the stock exhaust, I found it easier to reinstall the exhaust with the crossmember unbolted (but still attached to the tranny) supported by a jack and the tranny lowered to allow the hanger to slide in more easily.
Anyway, thanks again for everyone who helped and the articles written about the install. Take care.
-Leo
leojeng is offline
post #2 of 5 (permalink) Old 05-17-2004, 08:14 AM
94t-birdlx's Avatar
Send a message via AIM to 94t-birdlx Send a message via MSN to 94t-birdlx
Did you have any problems breaking free the exaust at the manifold? How did you get the bolts to turn? I hate exaust and I don't wanna break the studs.
Adam
"Technical skill is mastery of complexity while creativity is mastery of simplicity."
94t-birdlx is offline
post #3 of 5 (permalink) Old 05-17-2004, 10:00 AM
I haven't had any problems with the manifold studs breaking, and I used the impact on everywhere possible, with the overhead lift, and airtools, it's a 2 hour job, but I did the same thing once, and didn't have the converter all the way in.
Rich95XR7 is offline
post #4 of 5 (permalink) Old 05-17-2004, 10:03 AM Thread Starter
No I didn't have much problems. I just sprayed some WD-40 on the bolts, let them set for a few minutes and then loosened them. The bolts and nuts seem pretty sturdy although there is some rust on them. I don't think you should have a problem with them breaking. I used a pipe to extend my ratchet handle, so I could get more leverage on the bolts.
-Leo
leojeng is offline
post #5 of 5 (permalink) Old 05-17-2004, 10:12 AM
94t-birdlx's Avatar
I got some penetrator to spray on and I'll try and get the Air gun on them. thanks for the info. Hopefully they come out easy.
