I want a 5 speed! - TCCoA Forums
post #1 of 6 (permalink) Old 05-17-2004, 09:27 PM Thread Starter
I want a 5 speed!
Ok guys, I have been thinking, How hard would it be to convert my 97 4.6 liter t-bird to a 5 speed? would it mean swapping it with a 97+Gt five speed and throwing in a clutch or is there way more to it....and if so, what? Thanx guys...
-Dennis
Drives97Tbird is offline
post #2 of 6 (permalink) Old 05-17-2004, 09:34 PM
The Great Obucina's Avatar
USE THE SEARCH FEATURE
There is a tech article in the transmission section of the Tech Articles page located at the home page that gives a helluva lot of details on what to do. It will probably cost you double that of getting a newer 4R70W and swapping it in.
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 6 (permalink) Old 05-18-2004, 01:59 AM
Jimbobicus's Avatar
Send a message via AIM to Jimbobicus
I just dropped a 5-speed in my Bird. It wasn't all that hard, but it was a lot of work. I think that it cost me about $1600-$1800.... And it was worth every penny. If you shop around enough you might be able to do it cheaper than I did.
Jimmy
1993 Thunderbird 5.0
Dual exhaust - no cats - Flowmaster 40 series mufflers
T5 - Aluminum flywheel - Stage II clutch
1990 Thunderbird SC
All stock... For now...
Jimbobicus is offline
post #4 of 6 (permalink) Old 05-18-2004, 05:46 AM
Jedi Master
mn12xr7's Avatar
its gonna cost him more because he would have more fabrication to do, extending the shifter on the tranny, cutting a custom DS, making sure that the t-45 fits, the wiring....
-Orlando
mn12xr7 is offline
post #5 of 6 (permalink) Old 05-18-2004, 07:41 AM
Basically from what i have read, You'd need a T-45 trans, all the clutch setup and pedal, you'll also need a chip/tune to turn off all of the 4R70W controls in the EEC. Otherwise it's going to keep looking for the transmission. Also, you'd need the MN12performance shifterbox or have one made per papajohn's specs in the tech article.
Dennis Reinhart (i know i know) can order a DS built to the correct length
or www.dennysdriveshaft.com can also build you one
I'm sure there's probably someother parts i'm missing too. If you're serious about the swap, get in touch with someone who's done it. I believe CobraRthunder did the T-45 swap so he'd be able to help out. I'm sure there's other people out there too.
Green95LX is offline
post #6 of 6 (permalink) Old 05-18-2004, 09:30 AM
Jedi Master
mn12xr7's Avatar
make sure to get a 96-97 gt t-45 and not a cobra t-45 cause i read in a thread here before that they are different and the new ones would need more work to get it in......
not too sure though...
the man to talk to is CobraRThunder
-Orlando
mn12xr7 is offline
