strange clunk - TCCoA Forums
post #1 of 8 (permalink) Old 05-20-2004, 03:50 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
strange clunk
i got a bad clunck/metal hitting metal sound when i put my car in reverse, manually downshift, or even sometime when i put t in a foward gear. it comes from under the car, sounds like it might be a bad u joint or bad tranny mount or both. i was just wondering if anyone else ever had this and what the problem was.
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #2 of 8 (permalink) Old 05-20-2004, 04:24 PM
Eleventeenth Gear Poster
Aaron K.'s Avatar
Do you get any kind of clunk (as described here) when giving it light throttle while in gear? I have a clunk in my drive train and pretty much have all the symptoms you described, plus what I asked about above. I have a brand new solid trans mount, new U-joints, and poly differential and cross member bushings. I dunno what my problem is From what you described, it does sound like it may be your U-joints though. Maybe someone can give us a better method of checking them besides wiggling the DS back and forth.
Sold = 96 Thunderbird
Aaron K. is offline
post #3 of 8 (permalink) Old 05-20-2004, 06:38 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
no i dont have the clunk your talking about in that thread. i gotta get under my car and see if there's some play in the driveshaft. are u-joints expensive to replace?
Frank
2007 Dodge Ram 1500
Previous Rides:
post #4 of 8 (permalink) Old 05-20-2004, 09:04 PM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
how are the motor mounts, tranny mount, irs bushings????
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
post #5 of 8 (permalink) Old 05-20-2004, 09:07 PM Thread Starter
Formerly Fdawg97LX
Fdawg03SVT's Avatar
they're all stock, 56k on them
2007 Dodge Ram 1500
Previous Rides:
post #6 of 8 (permalink) Old 05-21-2004, 12:11 AM
The Great Obucina's Avatar
check that trans mount. When I had my transmission changed out in october, the OE mount was sheared in two(mad crazy torque)Mine did the same thing, clunk in reverse, clunk into drive, etc...
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #7 of 8 (permalink) Old 05-21-2004, 12:12 AM
Yeah, i agree it's probably your trans mount. I have new motormounts, and a stout rear differential mount and i still have the clunk. I've never replaced my trans mount, so i'm sure it's failed by now
Green95LX is offline
post #8 of 8 (permalink) Old 05-21-2004, 07:47 AM
Dusty's Avatar
Mine clunks going into reverse and somtimes into drive. No cluncking while moving. Had the problem before and replaced right half-shaft with junk yard replacement due to bad joint. Not sure if it is a U-joint or CV joint in these half shafts. Problem is back and Raxles are going in.
Dusty is offline
