size of tranny cooler hose - TCCoA Forums
post #1 of 4 (permalink) Old 05-23-2004, 04:19 PM Thread Starter
I've seen this before but couldn't find it today by searching.
What's the recommended kind of hose that will work best the transmission line when installing a tranny cooler? Read somewhere that if you just ask for transmission line, they give you something crappy. And it's 3/8th's, correct?
Grasshopper is offline
post #2 of 4 (permalink) Old 05-23-2004, 04:28 PM
3/8" is what ya need...
weswing04 is offline
post #3 of 4 (permalink) Old 05-23-2004, 04:31 PM
5.0 Chero's Avatar
I thought the steel tranny lines were 5/16? 3/8 would probly clamp down enough but I think you would be better off with 5/16 fuel oil vapor line
THE PYL !
91 Tbird lx 5.0 swap
GONE 93 5.0 Stang vert
86 F250 Diesel 4x4
GONE 89 Aerostar
2003 F350 Super duty
1996 Exploder
5.0 Chero is offline
post #4 of 4 (permalink) Old 05-31-2004, 07:08 AM
AED Specialist
A-Train's Avatar
Smile
Allen,
Use 3/8" ID transmission hose. I highly recommend Aeroquip socketless hose in a -6 size. That hose will never let you down and mine is almost 10 years old now.
You can also use 11/32" ID hose if needed. You'll need about 10 feet total and a fitting to adapt to the radiator fitting. If you are running the coolers in series, tap off the top fitting on the raditaor as it's the return to the transmission.
A-Train
2008 Acura TSX (5AT)
2012 Honda Ridgeline RTL (w/Navi)
Ex toy: 1995 T-Bird LX - ALLEN supercharged, 2000 Mustang GT 4.6L PI engine, lot's of goodies...
12.74 @ 109.45 mph (BEST E.T. BEST MPH)
325 RWHP/380 RWTQ (SAE) on a dynojet
Tuned by Jerry W. from SCT
A-Train is offline
