shifting and the TPS - TCCoA Forums
post #1 of 9 (permalink) Old 05-23-2004, 05:53 PM Thread Starter
Question shifting and the TPS
I have been having some odd problems.
I replaced the 1-2 accumulator which got rid of one problem( jumping into neutral at high rpm's). But I still have a problem of it sometimes not wanting to shift out of 2nd.
The thought had occured to me to replace the 2-3 accumulator but I just wanted to run this past you guy's
I was wondering what the symptoms of the TPS going bad would have on the tranny, if any, is it an intermittent thing or complete failure?
chunk is offline
post #2 of 9 (permalink) Old 05-23-2004, 07:12 PM
3rd Gear Chirper
hotbird's Avatar
Could be either (intermittent or hard failure). If it was a hard failure she probably wouldn't want to run, or would run very rough. Intermittent failures are harder to catch, if it comes and goes enough the EEC will catch it and set a code.
hotbird is offline
post #3 of 9 (permalink) Old 05-23-2004, 07:21 PM Thread Starter
Would or could it have an effect on the shift points like not wanting to shift out of a gear?
chunk is offline
post #4 of 9 (permalink) Old 05-26-2004, 06:55 AM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
If the accumulator was broken, then yes. If it was the TPS, the car probably wouldn't even stay at an idle state if you put it into gear (at least when my TPS went, it wouldn't) If you want, use a multimeter and test the TPS, it should be around .98 give or take a few.
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
post #5 of 9 (permalink) Old 06-02-2004, 08:25 PM
Audiobahnbird's Avatar
Send a message via AIM to Audiobahnbird
where do i put the multimeter to test my tps, at a quick glace it looks hard to get at but i could be wrong. I think my tps is just about gone.....sometimes at idle in gear it almost stalls, how much is a new one??
Please enjoy my new and improved short signature- Russ
Audiobahnbird is offline
post #6 of 9 (permalink) Old 06-02-2004, 10:01 PM
Have you checked your MLPS? It can cause the transmission to neutral out and shift to 2nd at any time
Green95LX is offline
post #7 of 9 (permalink) Old 06-04-2004, 06:27 AM
kenshi's Avatar
To check the voltage, just stick the probes through the back of the plug against the wires. You needn't even pull the plug off. This works for a lot of sensors.
1994 Thunderbird LX 232
Discarded air silencer. Gutted cats. [email protected] mph at this point. 8.8" Trackloc differential with polyurethane bushings. PA manual valvebody. Sport springs.
1989 Thunderbird SC 5-speed
ESM ported supercharger. Performance exhaust.
2005 Yamaha YZF600R
kenshi is offline
post #8 of 9 (permalink) Old 06-04-2004, 09:38 AM
02 Explorer Pioneer
timb's Avatar
Chunk,
Since I know you did a trans swap and repinned the connector. Check to make sure that connector is fully seated and all the pins are all the way down. An intermittant connection there can cause the trans to stay in second
Birdless
timb is offline
post #9 of 9 (permalink) Old 06-04-2004, 12:00 PM Thread Starter
Figured it out just repinned the connector ' the right way' and now it's fine.
Thanks for all your help guy's
chunk is offline
