Humming noise coming from rear. - TCCoA Forums
post #1 of 8 (permalink) Old 05-23-2004, 07:18 PM Thread Starter
Pawn Shop Pro
antz_tbird's Avatar
Send a message via Yahoo to antz_tbird
When i'm driving down the road about 25-30 MPH I hear this humming noise coming from the rear. It quits as soon as i let go of the accelerator. What could this be?
antz_tbird is offline
post #2 of 8 (permalink) Old 06-03-2004, 09:10 AM
scottkornhaus's Avatar
My car does the same thing. Mine didn't start until I changed the pumpkin (i had to drop the exhaust and found out I had two leaks... so it might be that).
-Kornhaus
scottkornhaus is offline
post #3 of 8 (permalink) Old 06-03-2004, 08:09 PM
Audiobahnbird's Avatar
Send a message via AIM to Audiobahnbird
Too much gassy food?
Please enjoy my new and improved short signature- Russ
Audiobahnbird is offline
post #4 of 8 (permalink) Old 06-03-2004, 11:24 PM
Refrigerator Raider Hater
GreenBird's Avatar
Have the pinion angle checked.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #5 of 8 (permalink) Old 06-04-2004, 12:16 AM
Traveler's Avatar
Doesn't know the words?
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #6 of 8 (permalink) Old 06-04-2004, 05:52 AM
it only hums in third gear, going about 35-40. I talked to a buddy, and he said if it were the pumpkin/gears, it would make the noise constantly!
Any ideas?! I did find out that I had two air leaks in my exhaust. Could it be that vibrating or something?
-Kornhaus
post #7 of 8 (permalink) Old 06-04-2004, 06:20 AM
kenshi's Avatar
I experienced that. Eventually, the humming turned into chattering. I drained my differential oil and it looked like glitter. Now I have my precious 8.8" Tracloc differential. I'd recommend checking your oil first of all.
1994 Thunderbird LX 232
Discarded air silencer. Gutted cats. [email protected] mph at this point. 8.8" Trackloc differential with polyurethane bushings. PA manual valvebody. Sport springs.
1989 Thunderbird SC 5-speed
ESM ported supercharger. Performance exhaust.
2005 Yamaha YZF600R
kenshi is offline
post #8 of 8 (permalink) Old 06-04-2004, 06:51 AM
Glitter? I don't think I put fairy dust my in diff's.
Once you drain it, what is the easiest way to refill it?
-Kornhaus
