t-45 SWAP Question - TCCoA Forums
post #1 of 7 (permalink) Old 05-27-2004, 06:52 PM Thread Starter
t-45 SWAP Question
Are the t-45 transmission output yokes the same as our auto's and is the input shaft on the t-45's able to wiggle around alittle or do i have a bad bearing in mine.
REGULATOR is offline
post #2 of 7 (permalink) Old 05-27-2004, 07:17 PM
CobraRThunder's Avatar
Tou will need a T-45 yoke. And the output shaft shouldnt woble. The input shaft might have a tad bit of play in it. I strongly suggest you buy a new imput shaft bearing and replace it if you bought he trans used. What year and model is your transmission. Chris
4R70W From DirtyDog
CobraRThunder is offline
post #3 of 7 (permalink) Old 05-27-2004, 08:37 PM Thread Starter
Will the driveshaft be shorter or longer with the t-45
post #4 of 7 (permalink) Old 05-28-2004, 09:31 AM
You will need a driveshaft that is 1.5" shorter than stock, using the T-45 yoke. Give me your email. And search on this forum. I have written a lenghty Notes file on my swap that has all the info you will need From my swap. Chris
4R70W From DirtyDog
post #5 of 7 (permalink) Old 05-28-2004, 11:04 PM Thread Starter
my e-mail is [email protected] I have PMed you for the notes previously if you've sent them at that time i didn't receive them. I will watch for it and let you know
post #6 of 7 (permalink) Old 05-29-2004, 10:44 AM
You have mail. I had a few people whos email's were not sent due to Unknown email reaturs or full boxes. you may have been one.
4R70W From DirtyDog
post #7 of 7 (permalink) Old 05-29-2004, 11:53 PM Thread Starter
I have your e-mail. Thanks
