Trans in and speedo off - TCCoA Forums
post #1 of 8 (permalink) Old 05-29-2004, 01:02 PM Thread Starter
Put the tranny in from a 2000 Mustang GT(Thanks timb), only thing is the speedo is off.
What gear if any do I need to put in to fix?
I have a 3:27 gear ratio.
I had no idea the difference would be so noticeable between the two trannys....very nice
chunk is offline
post #2 of 8 (permalink) Old 05-29-2004, 08:09 PM
Cougar Pilot
BlackCat94's Avatar
Mine's off with 3.27's and an '00 Mustang GT trans. too, and nobody seems to know just why.
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #3 of 8 (permalink) Old 05-29-2004, 08:14 PM
02 Explorer Pioneer
timb's Avatar
The mustang output shaft has more splines so you need to change speedo gears to compensate. As long as you have a 3.08 or 3.27 you can use a gear. I just looked up an email I had...you need a purple speedo gear Dan Newman can get it for you
Birdless
timb is offline
post #4 of 8 (permalink) Old 05-29-2004, 08:15 PM
Cougar Pilot
BlackCat94's Avatar
Thanks alot! I wonder why nobody told me this when I was in the process of swapping.
post #5 of 8 (permalink) Old 05-29-2004, 08:45 PM Thread Starter
Thanks again timb
I'll give Dan a call.
chunk is offline
post #6 of 8 (permalink) Old 05-29-2004, 11:02 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
I posted the output shaft differences a long time ago...guess nobody paid attention.
The Mustang uses an 8 tooth,and the Tbird uses a 7 tooth for the speedo drive gear.
JL
Fuelly
Johnny Langton is offline
post #7 of 8 (permalink) Old 05-29-2004, 11:05 PM
JustinH's Avatar
search for output shaft, and its probably in at least a dozen posts.
I referenced to JL's post several times. Edit-make that 14 times I mentioned the term "output shaft"
http://forums.tccoa.com/search.php?s...der=descending
JustinH is offline
post #8 of 8 (permalink) Old 05-30-2004, 01:50 PM Thread Starter
Must have missed it, output shaft would not have come to mind unless mentioned.
Now I know.
chunk is offline
