code P0720 - TCCoA Forums
post #1 of 1 (permalink) Old 05-29-2004, 04:41 PM Thread Starter
code P0720
says "Output speed sensor circuit malfunction"
would a new vehicle speed sensor fix this problem? Its throwing two codes..both of them are the P0720.
im getting a delayed 1-2 shift ..the first time it has to shift after being started. it works fine after the first shift, until the engine is killed and started back up.
i have a new solenoid for the valve body also... just in case thats the problem??
weswing04 is offline
