Who is Running 4.10's? - TCCoA Forums
post #1 of 21 (permalink) Old 05-31-2004, 10:54 PM Thread Starter
Just a qustion, who is running 4.10's and what do you think of em?
-Dennis
Drives97Tbird is offline
post #2 of 21 (permalink) Old 06-01-2004, 12:19 AM
4 Cam Bird's Avatar
I am, I love them. I do lots of highway driving with them too. They are probably too much for auto xing though.
2011 CTS-V Wagon
4 Cam Bird is offline
post #3 of 21 (permalink) Old 06-01-2004, 08:21 AM
dode's Avatar
I have them as well, and I am very pleased with them.
John
1997 Mercury Cougar XR7
1992 Thunderbird GT 5.0L
dode is offline
post #4 of 21 (permalink) Old 06-01-2004, 12:18 PM
Kevin's Avatar
Send a message via AIM to Kevin
Have 4.30's and am happy with them.
But 4.10's would be perfect for any MN12. Hey, Mustang guys love the 3.73's, and our cars are a few hundred lbs heavier so we need a bit more gearing.
1992 Mercury Cougar XR7 5.0 - Rust In Pieces
1995 Mercury Cougar XR7, rust free Florida car - future 5.0 project
Kevin is offline
post #5 of 21 (permalink) Old 06-01-2004, 09:53 PM
I went with the "only" 3.73 but more stall speed method, works great!
rancherlee is offline
post #6 of 21 (permalink) Old 06-02-2004, 01:17 PM
I'm going with 4.10's in the Lincoln, lots of Mark Viii owners wished they would've went 4.10's or 4.30's instead of 3.73's...
Blown306 is offline
post #7 of 21 (permalink) Old 06-02-2004, 02:29 PM
Those running the 4.10's or 4.30's, what's your highway rpm's at 70 mph?
Grasshopper is offline
post #8 of 21 (permalink) Old 06-02-2004, 06:04 PM
Kevin's Avatar
At 2700 I think I'm doing about 60mph.
There is no speedo gear that works with the AOD's and 4.30's, so my speedo reads a bit fast. I have to figure it out by timing myself by 75 seconds on the 1.25 mile blocks around here.
Kevin is offline
post #9 of 21 (permalink) Old 06-02-2004, 06:16 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
did you guys upgrade your driveshafts with the 4.10's? if not when does the vibration kick in? is it at normal driving speeds?
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #10 of 21 (permalink) Old 06-02-2004, 08:21 PM
Kevin's Avatar
I upgraded my driveshaft because the ART CARR transmission I got wasn't for a car - but a truck and therefor 1" too long.
Rather than send it back and piss around with shipping and wasting more time - I had an F350 driveshaft shortened to 1" shorter than a stock Cougar Shaft, then had it ballanced.
On jackstands with the drivetrain going about 110mph - NO vibration in the car whatsoever.
Kevin is offline
post #11 of 21 (permalink) Old 06-02-2004, 09:53 PM
4 Cam Bird's Avatar
I bought a shaft through Reinhardt. I have had the car way too fast without vibration (on Y rated tires). Sure made a lot of wind noise though.
If you don't have an answer to your RPM question by Friday I'll make a note of it then and let you know.
2011 CTS-V Wagon
post #12 of 21 (permalink) Old 06-07-2004, 09:49 AM
4 Cam Bird's Avatar
Didn't have much time to post over the weekend, spent it working on my dad's car and at show and shines. But, I did check to see what I was turning at 70. It was 2500-2600 RPM with a 27" tall tire (255/45/18), close to stock tire height with an 18 inch wheel, if you have 17" wheels, you will most likely have a shorter tire and turn more RPM than that.
2011 CTS-V Wagon
post #13 of 21 (permalink) Old 06-07-2004, 10:41 AM
Thanks 4 Cam,
I run stock 15" chrome fans with 245/60's. Very close to stock circumference.
post #14 of 21 (permalink) Old 06-28-2004, 11:58 AM
Carlover007's Avatar
Where did you guys pick up the gears from?
Carlover007 is offline
post #15 of 21 (permalink) Old 06-28-2004, 03:34 PM
MadGoat's Avatar
Send a message via AIM to MadGoat Send a message via MSN to MadGoat
Yes, My question is the same...
MG
MadGoat's Birds
94 Thunderbird LX 4.6L PI
03 Aluminum PI Engine, J-Mod, Aluminum one piece drive shaft, 3.27's, 2.5" to single 3" custom MagnaFlow exhaust, 07 17x8 Bullit Wheels
97 Thunderbird LX 4.6L V8
RIP
MadGoat is offline
post #16 of 21 (permalink) Old 06-28-2004, 03:55 PM
MadGoat's Avatar
Check this out:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33731
I think this is what we use?!?! right?
MG
(my bad, This is a 9'' we have 7.5'')
MadGoat's Birds
RIP
MadGoat is offline
post #17 of 21 (permalink) Old 06-28-2004, 04:13 PM
No, we have 8.8 inch rear. I got my gears from Dan Newman, just like all my other Ford parts.
Rich95XR7 is offline
post #18 of 21 (permalink) Old 06-28-2004, 05:25 PM
MadGoat's Avatar
oh,
ok my bad.... You are right..
I saw this tech article that said 7.5...
good to know
MG
MadGoat's Birds
RIP
MadGoat is offline
post #19 of 21 (permalink) Old 06-28-2004, 09:40 PM
I wanted to upgrade to 4.1 gears and a new drive shaft, but should I get the chip before or after the gears?
post #20 of 21 (permalink) Old 06-28-2004, 10:00 PM
Before or at the same time. Your top speed would be like 65 without a chip and 4.10's. I'm just guessing at the top speed, so don't shoot me for being off.
post #21 of 21 (permalink) Old 06-29-2004, 08:19 AM
4 Cam Bird's Avatar
Top speed would be 78 if you had 3.08's stock and 83 if you had 3.27 stock, FYI.
2011 CTS-V Wagon
