How do you flash the TC? - TCCoA Forums
post #1 of 8 (permalink) Old 06-03-2004, 03:15 PM Thread Starter
Ashish's Avatar
Send a message via AIM to Ashish
I know how to breakstall the TC to get your rpms up and preload the drivetrain. If I am correct is flashing just mashing the gas?
1997 Birdie, its the good one. Limited Edition Sport Sold
9/6/03-9/7/03-J mod & Mark VIII TC 12/26/03-Apten Chip & 03 GT MAF 3/11/04-3/14/04-PI Cams & PI Intake 8/19/04-FRPP 3.73 Diffy2/26/05-SCT chip (burned by Ken B.)
1998 Z28 M6 5.7 LS1
Ashish is offline
post #2 of 8 (permalink) Old 06-03-2004, 04:27 PM
how do you "breakstall"?
weswing04 is offline
post #3 of 8 (permalink) Old 06-03-2004, 09:36 PM Thread Starter
Ashish's Avatar
Hold the break and hit the gas and hold it at the point right before where your tires break loose.
1998 Z28 M6 5.7 LS1
Ashish is offline
post #4 of 8 (permalink) Old 06-03-2004, 11:25 PM
Refrigerator Raider Hater
GreenBird's Avatar
you flash the TC by not brake stalling. go from idle to WOT real fast.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #5 of 8 (permalink) Old 06-03-2004, 11:28 PM Thread Starter
Ashish's Avatar
While we are talking about TC's what in the world is a loose or a tight TC?
1998 Z28 M6 5.7 LS1
Ashish is offline
post #6 of 8 (permalink) Old 06-04-2004, 03:24 AM
Sweet T
SanDiegoLXBird's Avatar
Loose TC's stall at higher RPMs, letting you brakestall into your powerband (if you have the tires to stick the launch) or they keep you from braking loose too bad if you just flash it.
Tight TC's, obviously then, have a lower "stall" speed.
SanDiegoLXBird is offline
post #7 of 8 (permalink) Old 06-04-2004, 12:30 PM
GreenBird's Avatar
lower stall TCs are for bigger vehicles, because it requires the low end torque. Trucks are the extreme example, an F150 stall is a good 500 rpms below our stock, and a mach1 stall is a good 1000rpms higher.
96 Alpine Green V8
post #8 of 8 (permalink) Old 06-04-2004, 12:45 PM
Jedi Master
mn12xr7's Avatar
has anyone used the mach 1 TC? is it the same as the marauder TC??
-Orlando
mn12xr7 is offline
