DS options for AOD - TCCoA Forums
post #1 of 12 (permalink) Old 06-06-2004, 01:47 PM Thread Starter
Jedi Master
mn12xr7's Avatar
DS options for AOD
you 4r70w guys have the option of upgrading to a 93 mark viii one piece aluminum DS for a good price
but what about us AOD guys??
is there an aluminum DS from another model that can fit without having to go aftermarket??
I was looking that the E Series vans, they have a aluminum DS as well and have a aod tranny as well..
does anyone know the length on this DS and if this would work??
-Orlando
mn12xr7 is offline
post #2 of 12 (permalink) Old 06-07-2004, 12:48 PM
High Output Poster
91HellCat's Avatar
Send a message via AIM to 91HellCat
I have heard that the aluminum one piece mark VIII DS will work on our AOD cars with a tight fit.
1991 Ford Mustang GT
1998 Lincoln Continental
1999 Mercury Mountaineer 5.0
91HellCat is offline
post #3 of 12 (permalink) Old 06-07-2004, 12:55 PM Thread Starter
Jedi Master
mn12xr7's Avatar
really? I didn't know this
the DS size for our AOD's is 57 7/8 inches
the DS size for 4r70w's is 57
the mark viii DS is actually smaller than ours...
-Orlando
mn12xr7 is offline
post #4 of 12 (permalink) Old 06-08-2004, 09:45 AM
High Output Poster
91HellCat's Avatar
Hmmm...maybe I was misinformed.
JTurmel got a DS from Dennis for his 5.0 T-bird, but he is running a 4R70W in his car.
post #5 of 12 (permalink) Old 06-08-2004, 09:50 AM Thread Starter
Jedi Master
mn12xr7's Avatar
yeah thats why he has a mark viii DS
i was thinking of buying an econoline van DS, since they are all aluminum and are from an aod, cut it and balance it for our use, what do you think??
-Orlando
mn12xr7 is offline
post #6 of 12 (permalink) Old 06-08-2004, 11:25 AM
High Output Poster
91HellCat's Avatar
Is the diameter of the E series gonna be an issue? Otherwise, I say go for it as long as you get it balanced.
post #7 of 12 (permalink) Old 06-08-2004, 12:29 PM Thread Starter
Jedi Master
mn12xr7's Avatar
gonna wait till my pops gets home, he has an econoline he uses for work, i'll take measurements and let you know, unless i can find them on somewhere, i'll keep you posted
-Orlando
mn12xr7 is offline
post #8 of 12 (permalink) Old 06-08-2004, 12:35 PM Thread Starter
Jedi Master
mn12xr7's Avatar
4" diameter, guess not....
-Orlando
mn12xr7 is offline
post #9 of 12 (permalink) Old 06-08-2004, 01:58 PM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
JordanSypek's Avatar
WWW.BROOKLINEMACHINE.COM
$400, all aluminum, Spicer Joints, It was done in 3 days, made from scratch.
Tell them what size you need, and they will do it up.
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
95 4.9 F150 4X4 M5R2)
JordanSypek is offline
post #10 of 12 (permalink) Old 06-09-2004, 11:27 AM
jturmel's Avatar
Is that right?
I figured out what size I needed and ordered according to that, it was 1448mm (~57", which is same as 3.8 N/A and SC), I believe the Mark VIII shaft needs to be cut down shorter when used in 3.8 applications so that means I did not order a Mark VIII shaft.
Figure out what size you need then call up Dynotech. I do not recoomend using Dennis Reinhart, getting my driveshaft through him was a huge ordeal I would not want anyone to go through.
-J
1991 Sport 5.0
RIP 1991-2006
jturmel is offline
post #11 of 12 (permalink) Old 06-09-2004, 12:09 PM Thread Starter
Jedi Master
mn12xr7's Avatar
woops! i misunderstood I thought 91hellcat had said that you did, but i just read his reply wrong, my mistake
-Orlando
mn12xr7 is offline
post #12 of 12 (permalink) Old 06-09-2004, 12:28 PM
jturmel's Avatar
The rear of the 3.8 and 5.0 blocks end up in the same spot, so if you want a shaft for a 5.0 AOD it is the same as the 3.8 AOD, and if you want one for a 5.0 4R70W then it is the same as the 3.8 4R70W.
-J
1991 Sport 5.0
RIP 1991-2006
jturmel is offline
