j-mod finished (almost) - TCCoA Forums
post #1 of 2 (permalink) Old 06-07-2004, 12:56 PM Thread Starter
hey everyone,
I just finished installing the 99 valve body and the upgraded springs and pistons. The 1-2 and 2-3 shifts are great.. not too hard but definitely noticeable. The only problem is that instead of overdrive i go into neutral. I did some searching on here and found that it is most likely the od band slipping off. In the threads i found, i didn't see anything too in depth on how to fix it. If you can explain to me (or give me a link to a thread that tells what to do to fix it) I would really appreciate it. Thanks for the help.
-Erik
emg1485 is offline
post #2 of 2 (permalink) Old 06-08-2004, 10:23 AM Thread Starter
never mind,
I found a good thread that should help me figure it out. Thanks anyways...
emg1485 is offline
