tranny rebuild - TCCoA Forums
post #1 of 5 (permalink) Old 06-20-2004, 08:41 PM Thread Starter
Formerly known as lfteyechicken
NtenseTbird's Avatar
Send a message via AIM to NtenseTbird
tranny rebuild
ok, I have a 97 bird, and the problem resides in the fact that the car doesn't want to shift into second gear, I have to kindof feather the throttle to get it to shift, and then when I slow down or coast to a stop, the car bogs down, and right before I come to a stop the car hits back to normal (when I say hit, the car jerks mildy, not violently back to normal.) I have been told that the clutch plates are welding together and I need a rebuild. I have a mechanic friend that is going to oversee me rebuilding the tranny (Hands on learning) But I need to know what to replace. I was thinking it was the electronic shift mechanism thing, but I was told the clutch plates, any Ideas??? and what parts do I need to get to fix the problem.
NtenseTbird is offline
post #2 of 5 (permalink) Old 06-20-2004, 10:57 PM
Silver95Bird's Avatar
While it's possible the 1-2 accumulator has gone bad, 97s should have had the better one from the factory. So that makes the most likely culprit the roller one-way intermediate clutch. Delayed 1-2 shifts, or shifts into 2nd gear with a jerk or a bang are common. And by the way, clutch plates don't weld together. Run far far away from whoever said that and don't look back. They don't know a clutch plate (or any other various items) from a hole in the ground.
Silver95Bird is offline
post #3 of 5 (permalink) Old 07-13-2004, 03:10 PM Thread Starter
ok, so this roller one way clutch thing, is that all I need to replace, what will be involved with replacing that, full rebuild, or what.
post #4 of 5 (permalink) Old 07-13-2004, 03:42 PM
JustinH's Avatar
if you aren't going to rebuild it to Jerry's specs then just junk that tranny and put a new model 4r70w in there.
JustinH is offline
post #5 of 5 (permalink) Old 07-13-2004, 07:09 PM
agreed.
