Difference in trannys?? - TCCoA Forums
post #1 of 21 (permalink) Old 11-25-2004, 08:20 PM Thread Starter
I am getting a 03 mach1 tranny next week somtime and was wondering what the difference is that makes them stronger then my stock tranny or even a GT tranny...
PS I am wondering what the best TC to go with would be?? somthing around 3000 stall?
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #2 of 21 (permalink) Old 11-25-2004, 10:54 PM
Silver95Bird's Avatar
The 03+ trannies have the same upgraded parts that the 5.4L trannies get. The gearsets are much stronger, among other things.
The TC you choose depends on the engine it's behind. A 3000 stall on a near stock engine won't be the best choice. A maurauder/mach1 TC would be a good choice for that IMO.
Silver95Bird is offline
post #3 of 21 (permalink) Old 11-25-2004, 11:21 PM
my 03 trans came out of a stang also. It does NOT have a VSS, or the gears on the output shaft to turn it. Other than that it's just ducky.
GO BIG OR GO HOME!!!
PoweredBy351C is offline
post #4 of 21 (permalink) Old 11-25-2004, 11:21 PM
I know for a fact that the 2003 converters are better than any previous year. They became furnace brazed, bearing on thrust surface, and they have the larger sprag assembly.
post #5 of 21 (permalink) Old 11-26-2004, 02:25 AM
Like Titles Matter
kdanner's Avatar
It will be quickest with about 4k stall. As said already it likely does not have teeth to drive the VSS. To replace the output shaft will require a full teardown, it's the last part to come out of the case. Might as well get a 7 tooth shaft to avoid the speedcal if you are keeping the gears you have. If you are going to a more manly gear, you'll need the speedcal anyway, so either 7 or 8 toth will be fine.
kdanner is offline
post #6 of 21 (permalink) Old 11-26-2004, 02:36 AM
Kris, What determines how much of a stall you should have; Is there a table or articles I could find somewhere to help myself and others choose the correct stall?
Dave
DMcBrideBoston is offline
post #7 of 21 (permalink) Old 11-26-2004, 03:51 AM
Like Titles Matter
kdanner's Avatar
Dave
My old rule of thumb is stupid simple. The typical engine makes good power in about a 2000 rpm range. Based on what he has for an engine, we know it runs out of steam at about 6000. So about 4000 would be optimal. This has always worked for me in any type of vehicle I have ever owned.
kdanner is offline
post #8 of 21 (permalink) Old 11-26-2004, 04:48 AM Thread Starter
so i have to tear this tranny down completely to change the teeth?
2004 F150
KrAzyT is offline
post #9 of 21 (permalink) Old 11-26-2004, 04:59 AM
Like Titles Matter
kdanner's Avatar
Yes all the way to a bare case really.
kdanner is offline
post #10 of 21 (permalink) Old 11-26-2004, 07:30 AM
Unless somebody has come up with a way to utilize the OSS to get the signal for the speedo, you'll have to swap shafts. In my situation, I said screw it until further notice.
GO BIG OR GO HOME!!
post #11 of 21 (permalink) Old 11-26-2004, 08:27 AM
Blackicelsc's Avatar
Send a message via Yahoo to Blackicelsc
So, if you find a '03 tranny out of a Mustang, with the "same" internal goodies as a 5.4, you have to pretty much tear it down to replace the shaft. In that case, would it almost be better to find a 5.4 tranny, and just install it?
if I had to tear a '03 tranny down to the bare case just to have a speedo, I would either say screw it, or tear down my old one, and replace all the "not up to 5.4 spec" parts...probably cost the same in the long run, no?
I say go drive the car now...find out what RPM you are at when traveling the speed limit(test 65mph, 45 mph, and 35 mph-make mental note of them), and then just install it with no VSS. When you want to go one of the popular 3 speed limits, just plant the tach at the proper rpm.
My 98 Mustang tranny uses a different speedo gear than my 94 mark VIII had. I havent figured out yet which gear to install, so for now I use my tach as my speedo!
p.s. I have a Mach 1 TC
while on the subject, since a stock 98 Mustang GT with a A/T came with 3.27 gears, and my mark VIII came with 3.08's, if I installed 3.27's, would my speedo instantly correct itself? I ask because I have no concept on how the electronic speedo's work. I am used to cables, gears, and noisy speedo's on ice-cold mornings!(old school).
I am not about to go through the effort of buying 3.27 gears just to get my speedo right. If i was gonna do a gear swap, I would 3.73 or 4.10 the car. But I am curious.
Ok, you can have your thread back
Blackicelsc is offline
post #12 of 21 (permalink) Old 11-26-2004, 02:12 PM Thread Starter
so the GT tranny would be a direct swap so to say? i can get one with around 5k on it for 375
2004 F150
KrAzyT is offline
post #13 of 21 (permalink) Old 12-12-2004, 08:06 PM
Ashish's Avatar
Send a message via AIM to Ashish
will a speedcal take care of the VSS problem. Also I do have the 3.73 gears I know with a 8 tooth shaft i will need a speedcal (if I use a 99+ GT tranny). Also what is the OSS?
1997 Birdie, its the good one. Limited Edition Sport Sold
9/6/03-9/7/03-J mod & Mark VIII TC 12/26/03-Apten Chip & 03 GT MAF 3/11/04-3/14/04-PI Cams & PI Intake 8/19/04-FRPP 3.73 Diffy2/26/05-SCT chip (burned by Ken B.)
1998 Z28 M6 5.7 LS1
Ashish is offline
post #14 of 21 (permalink) Old 12-12-2004, 09:40 PM
Output-shaft Speed Sensor. OSS
post #15 of 21 (permalink) Old 12-13-2004, 01:20 AM
Like Titles Matter
kdanner's Avatar
Speedcal is fine as long as the output shaft actually has a gear on it, many of the new ones don't.
kdanner is offline
post #16 of 21 (permalink) Old 12-13-2004, 11:37 AM
Johnny Five is Alive
WkStill's Avatar
Send a message via AIM to WkStill Send a message via Yahoo to WkStill
Im sure someone will eventually make a mod to use the OSS signal to drive an older VSS signal..
Note: the OSS is a Square wave, as the VSS is a Sine Wave.
1984 Merc Cougar
5.0L, GT40X HEADS, E303 CAM,X303 Valvetrain
1998 4R70W Controlled by Baumannator TCS., 3.73 Track Lock Rear., Bauman Lev 3 Shift Kit.
190LPH, 67mm EGR, 65mm TB, 73mm C&L MAF, 24lb/h Inj, TwEECer RT, A3M EEC-IV
TCCoA-AHole Crew 2004
Disclaimer: The opinions expressed in my posts are my own. They are not meant to start a flame war or discourage people. Just my honest opinion and nothing more
Just great, 4 mores years of GOP crap, Im republican, and I endorse this message
WkStill is offline
post #17 of 21 (permalink) Old 12-14-2004, 01:44 AM
many ford eec's will accept a square wave vss signal.
Visit my website:
http://www.p71interceptor.com
2vmodular is offline
post #18 of 21 (permalink) Old 12-14-2004, 01:58 AM
it's easy to spend over $1,000 on new parts when you're doing a quality "rebuild" on one of our trannies.
also to pull apart an 03' tranny and swap in an output shaft with vss teeth, all you need for tools is a front pump puller, socket set, and snap ring pliers. to fully "rebuild" one, you need some other specialty tools.
Visit my website:
post #19 of 21 (permalink) Old 12-19-2004, 12:53 PM
SplitPortBird's Avatar
I cant see any reason you cannot use the OSS for the Speedo singnal at all,, a Speed-cal might be needed to match the singnal to the speedo. Like it was said above the ford EEC just looks for a HIGH/LOW condition to calculate speed so whether or not its a Square or Sign wave should not matter. BTW where did the info come from that its different? I would believe both the VSS and OSS were of the same type of output device.
I've never opened up a new 4R70W,, Does the OSS ride on the output shaft threw a gear like the VSS did? for 96/97 guys might be able to change out there OSS gear to match the orig unit (if they were in fact different ones avail)
Brad M
SplitPortBird is offline
post #20 of 21 (permalink) Old 12-19-2004, 01:45 PM
When you pull out the OSS, you can see that it's a magnetic pick-up type sensor. That means there's a probably some sort of "toothed" trigger on whatever it takes it signal from. Kinda like the crankshaft position, or cam position sensors.
Or it's a hall-effect type trigger. But there are no gears on the OSS to drive it.
post #21 of 21 (permalink) Old 12-19-2004, 01:50 PM
Thanks,, now I know and knowing is half the battle.
Brad
