Vibration is cured-front U-joint was a goner - TCCoA Forums
post #1 of 2 (permalink) Old 11-28-2004, 12:12 AM Thread Starter
Blackicelsc's Avatar
Send a message via Yahoo to Blackicelsc
after a couple weeks knowing something wasnt right, and being a little angry I had done all this work to get a new tranny in, only to develope a new driveline vibration, I can finally drive my car the way I want to again.
The front U-joint that I installed 2 new end caps on, was shot. the new end caps didnt help much I guess(I removed the U-joint from the drive shaft when I swapped trannies-lost an end cap, so I installed a new one on the driveshaft flange side.)
anyway, long story short, I properly lined the yoke up to the tranny's tail shaft this time, rotated the drive shaft 180 degrees, and installed a whole new U-joint.
I am fully confident the U-joint was the problem(very obvious with car back on the rack).
had it up to 110+ mph, and it was "like butter"
thanks to all who helped!
Blackicelsc is offline
post #2 of 2 (permalink) Old 11-28-2004, 02:28 PM
Glad to hear it. Butter is good.
cragus is offline
