GT Transmission/3.73 rear - TCCoA Forums
post #1 of 7 (permalink) Old 12-06-2004, 05:12 PM Thread Starter
I'm toying with the idea of getting a FRPP Pumpkin at some point when I have the money... The problem is I have a '99 GT transmission in my Cougar. I know there are no gears that wor *reliably* with the 8 tooth OP shaft, and I would rather not go the way of a speedcal (want to keep it clean). That said, it would mean I would have to tear down the transmission to replace tho OP shaft.
I just skimmed through Trans 101, and found that the older (95) OP shafts where made of a weaker material than the 98+ ones, so I shouldn't use the OP shaft from my 95 tranmssion. What else should I do while in there (I've done the JMod)? This transmission could end up behind a 450hp DOHC 4.6 (maybe), so I would want to build it to handle that, possibly build extra in...
I'm guessing the following:
-New 7 tooth OP Shaft
-5.4L Panetary Carrier
-Forward Sun Gear
-7 direct clutch plates
-6 forward clutch plates
-Wave plate for SC (5.4?)
-HP intermediate clutch friction (if I drill to the >450 for the intermediate)
-2.7" OD Servo
-5.4L EPC Solenoid
Am I on the right track? Any other words of wisdom?
Thanks.
Best times:
Cougar281 is offline
post #2 of 7 (permalink) Old 12-06-2004, 05:14 PM
JustinH's Avatar
i would start with a 5.4 truck core and build it right to the T from jerry's article.
Good luck getting a frpp pumpkin dude, they are discontinued from ford.
Besides 373 isn't enough gear anyway. Get a mark8 housing and DIY.
JustinH is offline
post #3 of 7 (permalink) Old 12-06-2004, 05:18 PM Thread Starter
oops... too bad I didn't have the money when they where fir sale for likg $550 (still don't, but...)
/that might be a cheaper way to go... I don't want to go TOO nuts with the gears... I'll probably need to get a MMX driveshaft with 3.73's anyway, but going ftom 3.08 to 3.73's would probably be a BIG difference off the line...
ETA: What vehicles had the 5.4L/4R70W? It seems like all the trucks have the 4R100.
I'm looking for the less expensive meathod for the same result. I would think (I could be wrong though) that it would cost less to get the replacement parts (rebuild kit +) than get a new (used) transmission, get a rebuild kit, and any additions.
Best times:
post #4 of 7 (permalink) Old 12-06-2004, 08:16 PM
Most F-150's with a 5.4 had the 4r70w. The 250's up have the 4r100.
post #5 of 7 (permalink) Old 12-06-2004, 09:27 PM
Silver95Bird's Avatar
1998 Mark 8 output shaft.
Silver95Bird is offline
post #6 of 7 (permalink) Old 12-07-2004, 06:55 PM
will the 150 4r70w bolt right up?
mylittleblackbird is offline
post #7 of 7 (permalink) Old 12-07-2004, 06:58 PM
The 4.2 and 5.0 4r70w's will bolt to the 3.8's
The 5.4 and 4.6 tranny's will bolt right up to our 4.6's
