trains loop - TCCoA Forums
post #1 of 9 (permalink) Old 12-12-2004, 09:37 AM Thread Starter
trains loop
what is a trains loop and how does it work?
thunderchicken17 is offline
post #2 of 9 (permalink) Old 12-12-2004, 11:43 AM
jk69cat's Avatar
its supposed to keep the driveshaft in place should a joint fail. our cars have 2 from the factory
mn12 less!
jk69cat is offline
post #3 of 9 (permalink) Old 12-12-2004, 12:02 PM Thread Starter
so we dont need to put one on our cars right?
post #4 of 9 (permalink) Old 12-12-2004, 05:46 PM
jk69cat's Avatar
well i dont know how good they are if your planning on racing it. they are fine for the street .
mn12 less!
jk69cat is offline
post #5 of 9 (permalink) Old 12-12-2004, 05:49 PM
I wouldn't trust them for racing. I don't think that they are even welded on, and they're pretty thin, too.
SloMo228 is offline
post #6 of 9 (permalink) Old 12-12-2004, 07:01 PM
Here is a picture that shows the stock driveshaft loops:
As you can see in the picture, they do not completely encircle the driveshaft and are bolted to the car. I don't have my NHRA rulebook with me, but I don't think you need to upgrade these unless you're running some serious times at the track.
-Rod
post #7 of 9 (permalink) Old 12-12-2004, 08:31 PM Thread Starter
thats not a thunderbird is it?
post #8 of 9 (permalink) Old 12-12-2004, 08:37 PM
That's the underside of my 90 Cougar XR7, which is the same body platform as any 89-97 Tbird/Cougar (MN12). It may look a little different than the average Tbird/Cougar because the fuel tank is out, and due to the aluminum centersection and aluminum lower control arms that I installed.
-Rod
post #9 of 9 (permalink) Old 12-13-2004, 12:26 PM
Blackicelsc's Avatar
Send a message via Yahoo to Blackicelsc
NHRA rules require if you run slicks, you must have a drive-shaft loop that completely encircles the entire circumfrence of the shaft.
I dont care if you 16.50's...if you tech with slicks, and they want to have a peek, you better have one.
For the record, the factory driveshaft loops in that pic will satisfy most tech inspectors...because most of them dont know the difference between an over-flow bottle, and an empty coke can spraypainted black.
For the most part, NHRA rules are simply in place for your own safety, and that of other racers/spectators. if they want you to have a bigger loop, there is a reason for it.
they can be made/purchased/installed very easily. contact your local exhaust shop. Most of them will gladly weld up some flat iron for you. They even sell a nice two-piece design at summit so you can install a loop without removing the driveshaft.
Blackicelsc is offline
