2001 Mustang tranny swap - TCCoA Forums
post #1 of 8 (permalink) Old 12-13-2004, 07:46 PM Thread Starter
O.K. i've done my research and I think I have all the answers but I would like others to verify.
To make a 2001 Stang trans swap into a 95 LX I would need the following: . . .
1) Swap the MLPS from the old tranny to the new
2)Swap the TCC from the old to the new
3)Repin the connector
4)JMOD-Drill the seperator plate
Here is where I need assistance. . .
The 2001 Stang torque converter is 6 bolt. . . I use the flexplate from the 2001 Mustang. . . CORRECT or INCORRECT?
At this point I'm good to go. . CORRECT or INCORRECT?
All assistance if appreciated. Also any other advise is too.
pablo59 is offline
post #2 of 8 (permalink) Old 12-13-2004, 08:04 PM
Ya i believe you can use either a stang or a mark Flexplate. I think there the same correct me if i'm wrong. This is the correct way to repin the harness http://forums.modulardepot.com/showt...threadid=31261 I'm looking to do this swap also so iv been doing some research
Good luck
Matt
MattsLE97 is offline
post #3 of 8 (permalink) Old 12-13-2004, 08:56 PM
Blackicelsc's Avatar
Send a message via Yahoo to Blackicelsc
You will also need to move your shift lever from your old trans to the new one.
if you are going through the effort to do all this, I would recommend just buying a new TCC solenoid. They cost about $28 and knowing it is a new part gives peace of mind. it is MODEL YEAR SPECIFIC though, and goes with the CAR, not the year of the tranny...so for you, get a 95 TCC solenoid.
I just did a 98 Mustang tranny into my 94 Mark VIII. very easy
MLPS
TCC
moved the VSS over to the new trans
re-pin the connector
manual lever(shift lever)
I also got a Mach 1 TC, so I was good to go.
buy yourself a good can of trans-flush from the auto-part store. be sure to flush the tranny lines clean in BOTH directions.
other than that, you should be set.
see the link in Silver95Bird's 'work in progress" thread.
here is the link:
http://www.personal.psu.edu/tfg112/t...icle/swap1.pdf
it shows you how to change the manual lever over from your tranny to the new one.
Best of luck, and enjoy your new tranny when done!
Oh, and be sure to index your yoke/driveshaft so you can re-install it in the proper location on the new tranny to avoid any driveline vibes!
Blackicelsc is offline
post #4 of 8 (permalink) Old 12-13-2004, 10:34 PM
You'll need the flexplate from a Mark VIII, or maybe certain years of Mustang GT. The Cobra has an 8-bolt crank, so it definitely won't work. Did they even have auto Cobras, anyway? Anyway, I'd go with the 2001 GT flexplate to match the transmission just to be safe, but the Mark VIII one should work fine as well.
SloMo228 is offline
post #5 of 8 (permalink) Old 12-14-2004, 02:09 AM
repinning your 95' bulkhead connector for the 01' tranny should work. the tcc solenoid from your 95' will not physically fit the 01' circuit board without modification though.
some notes about the bulkhead connector pinouts are avaliable here:
http://www.p71interceptor.com/tranny...rnal/bulkhead/
Visit my website:
2vmodular is offline
post #6 of 8 (permalink) Old 12-14-2004, 08:35 AM
As far as getting the older TCC solenoid to fit the '01 electric circuit, just trim the top of the plug-in collar, as seen in Silver95Bird's thread that I posted the link from.
I used a saw-z-all, and then fine-trimmed the rest with an exacto-knife...worked out perfectly.
post #7 of 8 (permalink) Old 12-15-2004, 10:31 AM
I used some wire cutters on my TCC solenoid to trim it down. It's the only part of the transmission that I know works for sure.
SloMo228 is offline
post #8 of 8 (permalink) Old 12-16-2004, 03:37 PM
Whining Intakes Rock
Al_Florida's Avatar
Fine tooth hacksaw blade works good too.
# 0 rows returned
# drop table users;_
Al_Florida is offline
