trans leak - TCCoA Forums
post #1 of 7 (permalink) Old 12-28-2004, 04:36 AM Thread Starter
trans leak
my trans is leaking at the filler/dip stick tube. it looks like the hole is damaged, bigger than the tube. any fix other than some fuel tank puddy?
ying is offline
post #2 of 7 (permalink) Old 12-31-2004, 03:26 AM
Slowride's Avatar
Send a message via Yahoo to Slowride
Try replacing the tube first. Go from there. The seal can go bad on those.especially when it's removed......that's why the books say replace the tranny dip stick tube and/or the oil dip stick tube if removed.
Good luck
The early bird may get the worm, but the second mouse gets the cheese!!!
Slowride is offline
post #3 of 7 (permalink) Old 12-31-2004, 06:07 AM
Darrin's Avatar
Or you could just replace the o-ring on the tube that actually creates the seal for less than $1
Darrin is offline
post #4 of 7 (permalink) Old 01-11-2005, 10:17 AM
Send a message via AIM to chrisnack
Ditto, the o-ring doesn't usually seal up that great after you have removed it. Just need a new one, not a whole new dipstick.
NSN Motorsports
http://www.nsnmotorsports.com
"Fordless" - But I do have alot of Mercon V laying around...
'96 Eagle Talon ESI
Parts ---> Dan Newman - Town & Country Ford - 800-847-2047
chrisnack is offline
post #5 of 7 (permalink) Old 01-11-2005, 04:53 PM
girdnerg's Avatar
Make sure it is bolted up at the top bracket also. This keeps it pushed down to seal.
If the hole is damaged, I'm not sure what will hold up. I'd test it in a bucket of Mercon-V first to see if it eats it up. The putty you mentioned, JB-weld, epoxy.
Good luck,
Rob
girdnerg is offline
post #6 of 7 (permalink) Old 01-11-2005, 05:08 PM
High-temp RTV will most likely work..
NSN Motorsports
'96 Eagle Talon ESI
post #7 of 7 (permalink) Old 01-11-2005, 07:07 PM Thread Starter
finally got off my *** today and replaced the o ring on the tube. so far so good no leak!!!!!!!
ying is offline
