Sc transmission Question - TCCoA Forums
post #1 of 5 (permalink) Old 01-01-2005, 11:48 PM Thread Starter
does anyone know if u can hook a supersoupe transmission to a 94 4.6 engine or is this not possible do to soem reason. i do know that the bellhousing might be differnt but i have no knollege of weatjher they would wortk in unison.
Ford DrVr 86 is offline
post #2 of 5 (permalink) Old 01-01-2005, 11:52 PM
No you can not, different bellhousing. You would need an adaptor plate, and what's the use then. You can save money just by getting the correct trans. Make sure it's an 98 or newer.
Lonnie is offline
post #3 of 5 (permalink) Old 01-02-2005, 12:18 AM Thread Starter
trans
so a 98 or knewer manual trans will bolt right up
post #4 of 5 (permalink) Old 01-02-2005, 12:25 AM
You didn't say manual trans. The same thing holds true for the manuals though, not worth the effort when you can pick up a manual for less than what it takes to make a 3.8 trans to work. Any of the 4.6 Mustang trans will work but you have to work out the shifter location. They come up a little short to in placing the shifter in the same location in the tunnel.
Lonnie is offline
post #5 of 5 (permalink) Old 01-02-2005, 01:47 AM Thread Starter
thanks
thanks i really appreciate the insight. People rarlley answer my ?'s on here so thanks.
