replacment v6 transmission - TCCoA Forums
post #1 of 4 (permalink) Old 01-04-2005, 09:06 PM Thread Starter
Litning's Avatar
Ok, as some of you might or might not know, I am putting in a 4.3 into my car. I was/am planning on a late model mustang transmission (01-04) but I am unable to find out for sure if it is possible. Is it possible?
Also, I need some help in determining what torque converter I should use. I plan on keeping this as my daily driver, with OCCASIONAL drag racing. At most I will be at 220rwhp NA.
Without being very knowledgable about stall speeds and sh..crap like that, I am gonna have to rely on your input.
So, in short, I need:
To know if a 01-04 mustang V6 transmission will work in my tbird (1996) and if so, what modifications will need to be done to make it work.
To know what kind of TC should I start looking for?
Thanks for the help
Litning is offline
post #2 of 4 (permalink) Old 01-04-2005, 10:50 PM
What converter to use mostly depends on your budget and/or usage. If you are truely making some ungodly amount of torque buy the triple plate unit. If you have a stock 4.2 you are putting in you can get away with a explorer converter. You can install a marauder converter with the correct flexplate, that would be the most bang for the buck. There are several other options beyond that without spending $1200 as well, it rreally all depends on what you want.
post #3 of 4 (permalink) Old 01-24-2005, 04:52 PM Thread Starter
Litning's Avatar
Well, my plans are for a good daily driver, no ungodly amounts of power (meaning i will probably stay N/A). I will be making some trips to the local drag strip. Being my daily driver, I need something that will not affect my drivability in snow and ice.
My engine will be a slightly modified 4.2, I might gasket match the intakes and heads (that is still up in the air). I will be putting in either 3.73's or 3.55's. Should a mark viii converter be sufficent for my needs?
Litning is offline
post #4 of 4 (permalink) Old 01-24-2005, 05:49 PM
If it has round lugs,NO. If it has the rectangular lugs it should do fine, as long as you keep it cool and don't beat it constantly.
