traction loc unit - TCCoA Forums
post #1 of 11 (permalink) Old 01-05-2005, 05:58 PM Thread Starter
traction loc unit
i am taking my rear in to get rebuilt. i went with a complete new trac loc unit from auburn and was just curios if it has the clips already in it to hold the axle? just want to make sure i have all the parts before taking it in. thanks wes
adictd2 is offline
post #2 of 11 (permalink) Old 01-05-2005, 06:34 PM
No, the Circlips are a part of the halfshaft, not the differential.
Rich95XR7 is offline
post #3 of 11 (permalink) Old 01-09-2005, 09:55 AM
AUBURN Trac-Loc?
Originally Posted by adictd2
i went with a complete new trac loc unit from auburn.....
Since when did Auburn start making the Trac-Loc?
Confused 68COUGAR
68COUGAR is offline
post #4 of 11 (permalink) Old 01-10-2005, 04:19 AM
Don't get the difference between Trac Loc and Limited slip
I thought it was just different names on the same thing..
But I'm guessing that he's going to use this...
http://store.summitracing.com/partde...t=auburn+8%2E8
//Per
Thyg0d is offline
post #5 of 11 (permalink) Old 01-10-2005, 08:44 AM
They are the same thing, Ford just calls theirs Trac-Lock.
post #6 of 11 (permalink) Old 01-10-2005, 08:55 AM
I may be wrong, but Auburn uses "cones" and Ford uses "discs". The Auburn gives more holding power because the cones have more surface area than the Ford flat discs.
But they both work on the exact same principle, "friction".
69 F100 LWB w/460 Engine
post #7 of 11 (permalink) Old 01-10-2005, 09:15 AM
jk69cat's Avatar
auburn is a true posi where a ford trac lock is a limted slip
mn12 less!
jk69cat is offline
post #8 of 11 (permalink) Old 01-18-2005, 11:18 AM
Please define your term "True Posi"?
Please explain Your defination of a "True Posi" (Positive Traction).
The Trac-Loc (Traction Lock) & Posi (Positive Traction) are BOTH Clutch type Limited Slip Differentials. The Auburn is a Cone type Limited Slip Differential.
Curious 68COUGAR
68COUGAR is offline
post #9 of 11 (permalink) Old 01-18-2005, 12:10 PM
While we're at it...
This is what I'm going to put in..
http://store.summitracing.com/partde...204T28&FROM=MG
Thyg0d is offline
post #10 of 11 (permalink) Old 01-18-2005, 01:56 PM
jk69cat's Avatar
i posted it a while back and the post dissappered. mods , why did it dissapear?
mn12 less!
jk69cat is offline
post #11 of 11 (permalink) Old 01-18-2005, 05:43 PM
Torsen
Originally Posted by Thyg0d
You can't beat a Torsen on the Street or Road Race course!!!!!!
68COUGAR
68COUGAR is offline
