Jmod Help, Did I miss the post? - TCCoA Forums
post #1 of 30 (permalink) Old 01-09-2005, 04:17 PM Thread Starter
Yes I searched, everybody has different views on this though.
I wanna do the Jmod but I have alot of questions.
Will it shorten my transmission life or TC life?
It firms up the shifts and taks away the nasty shifting delay?
Which tech article do I look at to do the Jmod? I saw Shifty Business and a regular Jmod article, I'm lost. Any links?
Is there any other things I need to know to improve the Jmod, such as different parts from what I have here? Could these partsbe obtained from Ford or Napa?
F7AZ-7F251-AA Piston $13.58
F75Z-7F284-AA Spring $ 3.45
F7AZ-7H292-AB Piston $ 7.02
F6AZ-7A098-A Tranny Filter $26.64
EOAZ-7D189-A Piston $13.28
F75Z-7H188-AA Piston $21.90
F87Z-7F201-AA Spring $ 3.38
F2VY-7C155-A Gasket $ 2.95
F5AZ-7D100-A Gasket $ 4.17
F2VY-7A191-A Pan Gasket $13.51
What's the deal with the deep oil pan? What car does it come from? Is it a direct swap? Is it THAT much of an improvement?
What will leaving the 1-2 or 2-3 spring out do?
Mercon V the best stuff to use? 14 qts?
Do I just have the car off and drop the pan, drain fluid and start?
I have a B&M Shift Kit. How do I take that crap out and if I do will the shifts go back to normal or am I permanetly screwed?
Lots of questions I need each one covered. Thanks in advance!
Nightmist_Outlaw is offline
post #2 of 30 (permalink) Old 01-09-2005, 04:27 PM
#1 No it won't shorten the life of the transmission or torque converter if you do the right changes. Read everything before doing anything.
#2 read all of the tech articles there is no harm in knowing more than you need to.
#3 & #4 I don't see the updated pan listed there. Yes you need it ford updated it for a reason. I'm not sure on all of the other part numbers you need to read those articles to figure it out for yourself. Don't forget about the right drill bits.
#5 mercon V is not the best stuff it is the only stuff to use.
#6 Are you nuts?
#7 I don't know the B&M kit, at this time I would suggest you buy a newer valvebody. 98 is worth buying,but 99 is better.
In summary read all of the articles to find out what you will need, what you will be changing, and why.
post #3 of 30 (permalink) Old 01-09-2005, 06:17 PM
Darrin's Avatar
Originally Posted by dirtyd0g
#6 Are you nuts?
I hope he didn't mean what you thought he meant there Alan.
Darrin is offline
post #4 of 30 (permalink) Old 01-09-2005, 06:20 PM
That was the only way I could take it.
Oh the best place to get the parts is from ford. I doubt Napa carry's anything ,but the filter. Try Dan @ 1-800-847-2047
post #5 of 30 (permalink) Old 01-09-2005, 06:20 PM
Teeps's Avatar
Hey you haven't lived until you've taken a bath in Mercon.
1997 Sport - Work in progress:>
MP BB 304 Teksid 4v- w IC'd / Ported M112
Need:
Eaton pulley puller (VMP or BF preferred)
H/E
Cowl Hood
FRPS
FORE Regulator
Teeps is offline
post #6 of 30 (permalink) Old 01-09-2005, 07:00 PM Thread Starter
What did I mean?
post #7 of 30 (permalink) Old 01-09-2005, 07:14 PM
Rolling-Thunder's Avatar
Yes, you should get the 1997 upgraded pan. It costs under $20
It prevents fluid starvation when you accelerate from a stop, and taking a turn at the same time.
Steve - TCCoA member
2003 Crown Vic LX Sport
Thanks for the ride !
Rolling-Thunder is offline
post #8 of 30 (permalink) Old 01-10-2005, 02:39 PM
First tranny in my 94 cougar lasted only 89k. Second trany was a Ford reman to 95 specs to which I added the new style bonded accumulator pistons and the base level Jmod but without the spring in the 1-2 piston. LOVED the results and as far as durability.....180k (270k total on the car now) and an fluid change every 25k later and still ticking.
If anything, getting rid of the slip between shifts will extend tranny life.
P.S. I didn't upgrade to the later pan because I was cheap!
JoeB is offline
post #9 of 30 (permalink) Old 01-10-2005, 05:43 PM Thread Starter
Ok....
So should I get my directions from the Shifty Business article?
post #10 of 30 (permalink) Old 01-10-2005, 05:59 PM
The shifty business is a very good article and does simplify everything, but you should really read it all to know what you are changing.
post #11 of 30 (permalink) Old 01-10-2005, 09:14 PM Thread Starter
I read
I think I'm goin with the mild jmod. Can I leave the 1-2 and 2-3 spring out with stock gears and motor?
post #12 of 30 (permalink) Old 01-11-2005, 04:28 AM
Moderator & Teksid Whore
guitar maestro's Avatar
yup...i did and its awesome
guitar maestro is offline
post #13 of 30 (permalink) Old 01-11-2005, 07:58 AM
VicRattlehead's Avatar
i havent looked at the articles in a while, the jmod is part of both the first 2 articles, one tells you how to get to the valve body and how to do the springs and such, the other tells you how to modify the valve body itself. so you need to know both.
CMP Drag Racing
VicRattlehead is offline
post #14 of 30 (permalink) Old 01-11-2005, 09:10 AM Thread Starter
Do I even look at the one that refers to a pre-modified main control?
post #15 of 30 (permalink) Old 01-11-2005, 09:29 AM
Send a message via AIM to chrisnack
check my tranmission pic thread for pictures of what you are getitng into.. it's floating around in this section somewhere... i'll go bump it..
NSN Motorsports
http://www.nsnmotorsports.com
"Fordless" - But I do have alot of Mercon V laying around...
'96 Eagle Talon ESI
Parts ---> Dan Newman - Town & Country Ford - 800-847-2047
chrisnack is offline
post #16 of 30 (permalink) Old 01-11-2005, 12:48 PM
Links
Links you asked for:
http://www.tccoa.com/articles/tranny...ybusiness.html
http://www.tccoa.com/articles/tranny...n/page14.shtml
http://www.tccoa.com/articles/tranny...n/page18.shtml
I J-Moded my Lincoln Mark VIII a few months ago; it wasn't difficult.
The only challenge I had was getting my hands on the proper sized drill bits.
Mr. 92 is offline
post #17 of 30 (permalink) Old 01-11-2005, 01:45 PM
That is where Mcmaster comes in....
NSN Motorsports
'96 Eagle Talon ESI
post #18 of 30 (permalink) Old 01-12-2005, 09:19 AM Thread Starter
The light has shined through!
I went to see my dad at Ford today and told him I wanted my car to shift harder by modifyin the valave body. I told him I didn't like the BM shift kit and he said ok. So to my surprise he calls his friend, Eddie, at Pineville Transmission and Eddie tells me to come by with the papers. So I'm sh-ttn bricks and I go over there. he looks at it, says I have all this stuff and that I don't have to buy anything. He has the springs gaskets, pan, etc.
So I'm gettin a free Jmod and maybe I can talk my way into trac-loc with 3:73's and a Marauder TC for free too. It pays to know somebody.
post #19 of 30 (permalink) Old 01-12-2005, 10:36 AM
Thats awesome. Keep your fingers crossed.
ostack is offline
post #20 of 30 (permalink) Old 01-12-2005, 02:29 PM
96dirtybird's Avatar
punk !!!
96dirtybird is offline
post #21 of 30 (permalink) Old 01-12-2005, 10:51 PM Thread Starter
Attention Please!
Jmod is bein done on the 18th, with no payment !
post #22 of 30 (permalink) Old 01-13-2005, 06:28 AM
Well make sure you buy him lunch then.
post #23 of 30 (permalink) Old 01-13-2005, 07:01 AM
Sweet T
SanDiegoLXBird's Avatar
You'll know the deep sump pan because it has a little bump in the bottom, also has a different style filter IIRC. You can either get that pan or a B&M Deep sump pan that also holds an extra couple quarts of fluid, which will help keep trans operating temps down.
SanDiegoLXBird is offline
post #24 of 30 (permalink) Old 01-13-2005, 11:52 AM
so the upgraded pan is "only" off the '97 ?? Thanks!
post #25 of 30 (permalink) Old 01-13-2005, 12:25 PM
Send a message via Yahoo to goodguy
I was looking at this and didn't see the mod for a AOD
Is there one and do you have a link to it? Thanks
goodguy is offline
post #26 of 30 (permalink) Old 01-13-2005, 04:01 PM
Sweet T
96 or 97. Should be the same pan.
post #27 of 30 (permalink) Old 01-13-2005, 06:40 PM
that's what I thought, cuz I have a '96 and it has a bump/nipple on the bottom and does look deeper than my '95 !
post #28 of 30 (permalink) Old 01-13-2005, 10:34 PM
Blackicelsc's Avatar
Send a message via Yahoo to Blackicelsc
A JMOD...for free? Sounds like you are taking it to my shop for me to do for you!!!(but, you arent).
For some of us, doing things for friends gives us more satisfaction than any dollar amount can.
I have done 4 JMOD's...mine, and 3 freind's. I havent received a dime, nor would I accept a dime.
But...I am sure you will find SOMETHING the tranny-man could use...I "needed" some stuff for my car. I never collected a dime for my work, but I ended up with a Hayden tranny cooler, a nice 12" sub/amp/installation kit(used, of course,), and some MSD wires.
The guy who provided the "thump" is heavily into car stereo's. He showed up to have me do a full tune up, JMOD, new front struts, etc...I ended up with some nice stereo components...I knew nothing about sound systems, but installed the goodies myself...and love every minute of it.
My point is, you might be getting a free JMOD...but you might consider finding out what "tranny man" could use....perhaps some yard work? or better yet...shop clean up?
hell, if I were you, I'd spend alot of time at his shop, and learn as much as you possibly can. even try to help with the JMOD. Who knows...one day you might be "pimping" some work for him. If you run across some Mustang boys who want to know why your car BARKS into second gear, and theirs doesnt...send them to your tranny man...let them "pay him"...
Good luck, be sure to thank the guy plenty, and then drive by his shop and let him hear your rears chirp into second...that makes any tranny man happy!
Blackicelsc is offline
post #29 of 30 (permalink) Old 01-15-2005, 02:01 PM Thread Starter
Of course I'm helping. I'll prolly be doin more watchin than doin. That's ok though. BTW he's doin my gears too, same payment . Dad's best friend is awesome!
post #30 of 30 (permalink) Old 01-15-2005, 08:23 PM
Lucky you, i wish my dad knew more "tranny men", but luckily for me i got the guys from this site that live around my area and we are gonna give it a shot and see what happens, i cant wait till i hear those barks in second gear
ellocote314 is offline
