removing j-mod - TCCoA Forums
post #1 of 5 (permalink) Old 01-13-2005, 11:49 PM Thread Starter
removing j-mod
is there a manual or instrucion sheet anywhere online on how to remove the j-mod? do trannys out of 02 gt's even have the j-mod's? i just got a 02 gt tranny wit 9k miles on it for $200 and before i put it in my car i want to take out the j-mod, just trying to figure out how thanks
burittobob is offline
post #2 of 5 (permalink) Old 01-14-2005, 12:02 AM
VicRattlehead's Avatar
replace the valve body separator plate with a new one because the holes have been drilled bigger, and re insert the springs.
why would you want to remove a jmod??
CMP Drag Racing
VicRattlehead is offline
post #3 of 5 (permalink) Old 01-14-2005, 12:07 AM
J-Mod should be the first mod you do along with a good transmission cooler.
It doesn't sound like you even know what the J-Mod is.
Rich95XR7 is offline
post #4 of 5 (permalink) Old 01-14-2005, 07:53 AM
J-Mod is just that - a modification to a stock tranny. If the tranny is stock, it doesn't have a J-Mod.
johnaec is offline
post #5 of 5 (permalink) Old 01-14-2005, 08:19 AM
Darrin's Avatar
Please note that a j-mod HELPS the transmission. It will make it work better and live longer.
I can see no reason to ever undo one. I can see putting springs back in to soften shifts, but the modifications to the valve body should always be done to any 4r70w for a car and never be undone. This stuff should have been done from the factory.
If the tranny is stock, it doesn't have one as several others have pointed out already.
Darrin is offline
