4R VB universal? AODE VB universal? - TCCoA Forums
post #1 of 5 (permalink) Old 01-17-2005, 10:22 AM Thread Starter
Question about 4R vb's.....do all 4R vbs work with all 4R's. If I modded a 93 vb will it fit on a 97? I know my way around AOD's pretty well, but I am getting into 4R's now. Sma e question with AODE's.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #2 of 5 (permalink) Old 01-17-2005, 10:41 AM
Johnny Five is Alive
WkStill's Avatar
Send a message via AIM to WkStill Send a message via Yahoo to WkStill
The newer VB's are better. I wouldn't use an older style VB in a new 4r
There is a conversion kit to convert the dowl pins to use the older style 4r in a new style 4r trannie.
1984 Merc Cougar
5.0L, GT40X HEADS, E303 CAM,X303 Valvetrain
1998 4R70W Controlled by Baumannator TCS., 3.73 Track Lock Rear., Bauman Lev 3 Shift Kit.
190LPH, 67mm EGR, 65mm TB, 73mm C&L MAF, 24lb/h Inj, TwEECer RT, A3M EEC-IV
TCCoA-AHole Crew 2004
Disclaimer: The opinions expressed in my posts are my own. They are not meant to start a flame war or discourage people. Just my honest opinion and nothing more
Just great, 4 mores years of GOP crap, Im republican, and I endorse this message
WkStill is offline
post #3 of 5 (permalink) Old 01-18-2005, 01:07 PM Thread Starter
So the answer is no - there is a dowl pin change? It isn't that I would want to do this kind of swap - but I assume that NEW 4r VB's fit ALL old 4R's correct? The tranny istself is cake.....it is the vb diffrences and control that gets me all confused.
post #4 of 5 (permalink) Old 01-18-2005, 08:39 PM
Blackicelsc's Avatar
Send a message via Yahoo to Blackicelsc
well, since I have read that many folks have advised you "update" to a 99+ VB, I would suspect they are interchangeable.
Blackicelsc is offline
post #5 of 5 (permalink) Old 01-18-2005, 09:21 PM
Silver95Bird's Avatar
With the sleeves to fo over the dowel pins on the VB, a 99+ (or best an 01+ VB) can be retrofitted to any AODE/4R70W. It's more a matter of year than model IIRC. 96+ have a different thickness plate, and there are different EPC brackets - so if you update the VB to a 96+ on a pre96 car, you'll need the correct bracket. From what I gathered from Jerry's article on our site, a 94 AODE VB will interchange with a 94 4R70W VB physically. There may be minor spring difference inside, but there have been dozens of those changes over the years, and none of them should be that drastic. You can't fit a pre96 VB onto a 96+ trans (luckily).
Silver95Bird is offline
