Trans cooler - TCCoA Forums
post #1 of 8 (permalink) Old 01-17-2005, 04:48 PM Thread Starter
Trans cooler
I recently purchased a trans cooler and was wondering if any one had some pics of them installed and of how they plumbed it in. Thanks
doubleclutch is offline
post #2 of 8 (permalink) Old 01-17-2005, 04:58 PM
DMcBrideBoston is offline
post #3 of 8 (permalink) Old 01-17-2005, 04:59 PM
Click
Maybe try a search once I would take a pic of mine buts its like 0 degress outside right now
MattsLE97 is offline
post #4 of 8 (permalink) Old 01-17-2005, 05:16 PM Thread Starter
To further this question should I plumb into the existing tranny lines or bypass the factory cooler altogether?
post #5 of 8 (permalink) Old 01-17-2005, 05:26 PM
If the car will be driven in a cool/cold climate at all, I'd recommend installing the trans cooler in line with and just after the factory cooler.
Here are some pics of my B&M 28,000 GVW cooler on my 90 XR7. Since it is a warm weather only car, the cooler completely bypasses the factory cooler.
The 24,000 GVW cooler on my 94 LX is routed in line with the factory cooler, since I drive that car year round (and it gets pretty cold here in the winter). I don't have any pictures of that setup, but it's mounted in the same location.
-Rod
post #6 of 8 (permalink) Old 01-17-2005, 05:40 PM
I have the 24k# on my Cougar, and I have no heat exchanger in my radiator (Cobra Radiator), but even here in MO when it was in the 30's or below, the trans still lifted the temp needle a little...
Best times:
Cougar281 is offline
post #7 of 8 (permalink) Old 01-17-2005, 07:23 PM Thread Starter
Ok the next question is, if I kept the factory heat exchanger in the system, should the should the cooler be mounted before, or after, or does it matter at all?
post #8 of 8 (permalink) Old 01-17-2005, 08:45 PM
I'd put the aftermarket trans cooler after the factory cooler.
-Rod
