rear end 'thunk' - TCCoA Forums
post #1 of 5 (permalink) Old 01-20-2005, 10:29 AM Thread Starter
Geek w/Gearhead Complex
Fubarian's Avatar
Question rear end 'thunk'
when I'm driving down the road, I hear a thunk thunk thunk thunk coming from the rear. Hitting the Ebrake doesn't stop it but it does change frequency with speed.
I haven't got under to take a look yet, but I have looked around from the rear -- nothing's fallen off or hanging down
ideas / guidence?
96 Mark VIII [email protected] :: 03 radiator/fan - j-modded trans - BBK UD pulley kit - dual gauge pod - 28,000 B&M transcooler (w/ AN fits) - 3.73 locker (with speedo gear) - 180' thermo - 8.5mm wires - colder plugs
soon to install : "fixed" heads and a damn tune. Project snaked8 continues...
Fubarian is offline
post #2 of 5 (permalink) Old 01-20-2005, 10:54 AM
Blackicelsc's Avatar
Send a message via Yahoo to Blackicelsc
sounds like an axle problem, or a hub bearing. Thump-thump-thump isnt a good thing. especially if it changes frequency with speed changes.
of course, you could have a separated belt in your tire...I would jack up one side at a time, and in neutral, spin the tire....watch it to see if it is OOR(out of round). then check the other side.
best thing to do when dealing with a driveability noise is, start from the gound-up. Literally.
tires, wheels, hubs, axles, bearings, mounts, U-joints,driveshaft.
there are many things that you can SEE, so like i said... start at the ground, and work your way up/forward/in.
Blackicelsc is offline
post #3 of 5 (permalink) Old 01-20-2005, 08:48 PM
ITT-BIRD's Avatar
Sir Will posted vids of his bad rear bearing not all that long ago ... scary site for sure.
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
post #4 of 5 (permalink) Old 01-20-2005, 11:14 PM
is it more of a growl? growls' tend to be bearings ... just on a hunch, pop your centers off, and see if all your lugs are good and solid, in other words, make sure yo havent snapped a stud ... can you pin point whether or not its coming from inside the diff or not?
thumphed is offline
post #5 of 5 (permalink) Old 01-21-2005, 11:16 PM Thread Starter
Fubarian's Avatar
definately not a growl -- and I drive a lincoln I can see all my lugs all the time
no, its definately coming from the drivers side. Friend of mine is guessing CV boot which I guess would make sense (like its ripped and just floppin around). We'll see though - nice storm coming in this weekend so I don't know if I can make it to the parents place to check it all out.
Fubarian is offline
