the same old jmod question.. - TCCoA Forums
post #1 of 5 (permalink) Old 01-23-2005, 11:54 AM Thread Starter
Birdman232's Avatar
In the next day or two, I'll be ordering the parts to do the jmod this weekend. Just making sure, if this everything I need for the "hardest" shifts, or the 350hp or whatever level it is?
F7AZ-7F251-AA Piston
F75Z-7F284-AA Spring
F7AZ-7H292-AB Piston
F6AZ-7A098-A Tranny Filter
EOAZ-7D189-A Piston
F75Z-7H188-AA Piston
F87Z-7F201-AA Spring
F2VY-7C155-A Gasket
F5AZ-7D100-A Gasket
F2VY-7A191-A Pan Gasket
Plus all the drill bits, mercon V, and a trans cooler.
Since I have a 97 i dont need the deep pan, and I dont want to mess with the od servo(I believe its called) since the band may fall off and people say its a pita. So is this what I need? (btw) i did a search, and this is what I came up with, but it was a post in 2002, just making sure this is still up to date.
Birdman232 is offline
post #2 of 5 (permalink) Old 01-23-2005, 12:24 PM
AED Specialist
A-Train's Avatar
Smile Nope...
Birdman16,
F7AZ-7F251-AA 1-2 Accumulator Piston - CORRECT
F75Z-7F284-AA 1-2 Acc TOP Spring - CORRECT
F7AZ-7H292-AB 2-3 Accumulator Piston - CORRECT
F6AZ-7A098-A Tranny Filter - CORRECT
EOAZ-7D189-A SHORTEST REVERSE servo - CORRECT
F75Z-7H188-AA 2.7" OVERDRIVE servo - CORRECT
F87Z-7F201-AA OD Servo Return Spring - CORRECT
F2VY-7C155-A Gasket INCORRECT
F5AZ-7D100-A Gasket INCORRECT
F2VY-7A191-A Pan Gasket NOT REQUIRED
You really want the '96 and up main control gaskets. They are p.n.
- 1L3Z-7C155-AA
- XW7Z-7D100-AA
These are the most up-to-date gaskets for a '96 and up main control. I'm not sure if any of the above part numbers have been superseded, but you'll always get the most updated parts from the Ford dealer.
The pan gasket is reusable provided it's not damaged. You don't need a new one unless someone has stuck a cork gasket in there during a service. I've seen tons of them on Crown Vics.
Nope. You already have it (or you should at least).
Ok, then delete the OD servo and spring from the above list. REMEMBER, do not touch the OD servo when doing the J-Mod. Just removing from the bore can and will cause the OD band to move out of place. If you are replacing the OD servo, just be careful.
Looks like it. Just remember, a hard shift is fun, but it beats up on the driveline components. If you are making 400 HP, then drill it for 400 HP setting. If you aren't making 400 HP, get a neck brace.
A-Train
2008 Acura TSX (5AT)
2012 Honda Ridgeline RTL (w/Navi)
Ex toy: 1995 T-Bird LX - ALLEN supercharged, 2000 Mustang GT 4.6L PI engine, lot's of goodies...
12.74 @ 109.45 mph (BEST E.T. BEST MPH)
325 RWHP/380 RWTQ (SAE) on a dynojet
Tuned by Jerry W. from SCT
A-Train is offline
post #3 of 5 (permalink) Old 01-23-2005, 12:56 PM Thread Starter
Birdman232's Avatar
I appreciate it man, no, I just did a tranny fluid change w/ new filter and gasket(10k ago), I didnt drain the TC though, so i'll go ahead and do it this time. It has the rubber gasket I got from the Ford stealership here in town, so I guess I'm good.(I do have the deep pan, positive)
For the 400HP level i just want the hard shift. Not like I'll really have 400hp from a basic built up engine but ohwell. My shop teacher and I are thinking about a built up Supercoupe engine to be put in this car this summer when we can use his personal shop and have more time to do it, not real sure on the specifics just yet, but it wont retain the stock 3.8 much longer.**I know...I'll need a better rear end and halfshafts, and some other things...I'll be picking alot of it up at the local pullapart as a parts car SC**
post #4 of 5 (permalink) Old 01-23-2005, 01:57 PM
AED Specialist
A-Train's Avatar
No problem, glad to help out...
A-Train
A-Train is offline
post #5 of 5 (permalink) Old 02-10-2005, 07:14 PM
ITT-BIRD's Avatar
Originally Posted by A-Train
Birdman16,
- 1L3Z-7C155-AA
- XW7Z-7D100-AA
A-Train
I got separator plate gasket numbers 1L3Z-7C155-AA & 1W7Z-7D100-AB.
Question on TCCs... 01 pn F8AZ-7G136-AA compared to '96 pn F5AZ-7G136-AA. Are these compatible or unsure?
I am also getting F75Z-7F284-BA 1-2 top spring.
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
