Pump O-Ring - TCCoA Forums
post #1 of 7 (permalink) Old 02-01-2005, 10:42 AM Thread Starter
Pump O-Ring
I am in the process of putting my 01 trans. back together, and I have the large pump seals that go around the outside edge of the pump, but I forgot to get new o-rings for where the pump slides onto the input shaft. Looks like there are 2 o-rings. With this new of a trans., would I need to bother replacing these, or can I get away with leaving them alone? I really don't care either way, and would rather replace a $2 o-ring, than have it cause the trans. to puke later on, but hey, a $1 saved right now is better than nothing, if I can help it.
Jay
FordMan77 is offline
post #2 of 7 (permalink) Old 02-01-2005, 11:34 AM
I think you are talking about the 1 piece teflon seals(white) leave them alone, you can only damage them by changing them.
post #3 of 7 (permalink) Old 02-01-2005, 03:34 PM Thread Starter
I guess. I could have swore that there was a black O-ring near the end of the pump housing. I'll grab a pic when I get home and double check. No need to create a problem when I *should* be done. Thanks Alan
Jay
post #4 of 7 (permalink) Old 02-01-2005, 05:13 PM
Are you talking about the large 0-ring around the outside?
post #5 of 7 (permalink) Old 02-02-2005, 01:12 AM Thread Starter
Ok,
A.- I am a moron. The ring I was thinking about is actually a metal snap ring. There seem to be several on the end. Nevermind on that.
B. The seal that is between the 2 parts of the pump assembly (the yellow stripe in the pic above). Should I even bother that? It looks fine, but hey, what do I know? I have 2 new seals for mounting the pump to the rest of the trans., so that's cool. I know where/how those go in. And I saw the nylon ring you referred to first, it's yellow, and is sitting on the backside of the pump. Not bothering it at all per your instructions.
thanks!
Jay
post #6 of 7 (permalink) Old 02-02-2005, 06:19 AM
Originally Posted by FordMan77
Ok,
thanks!
Jay
There are two seals on the pump. The o-ring which you see in that picture painted yellow. Then there is a black gasket that seals the pump to the case. I'm not sure but I think the nylon you are referring to is the thrust spacer.
post #7 of 7 (permalink) Old 02-02-2005, 09:55 AM Thread Starter
Yep, then those are the 2 I have. the one from pump to case I know, and then the other must be for the one w/ the stripe on it. Thanks for straightening me out on that. I tend to overthink things when it's something expensive that only takes one f-up to destroy.
Appreciate it
Jay
