carrier bearing - TCCoA Forums
post #1 of 1 (permalink) Old 02-04-2005, 01:28 PM Thread Starter
Geek w/Gearhead Complex
Fubarian's Avatar
Unhappy diff play
ignore the title, it isn't the carrier bearing...its something else
( http://forums.tccoa.com/showthread.php?t=56728 ) The 1/2 shaft has some play (up/down not in/out) in it on the pass. side. It's just a little bit, but enough.
good thing is I have a diff to swap out (my ole 3.07 diff) but I'm curious as to what causes this -- its a new diff, maybe a year old and I used the good stuff for lube in the thing. Oh well, anyone know what the procedure is to replace the thing?
96 Mark VIII [email protected] :: 03 radiator/fan - j-modded trans - BBK UD pulley kit - dual gauge pod - 28,000 B&M transcooler (w/ AN fits) - 3.73 locker (with speedo gear) - 180' thermo - 8.5mm wires - colder plugs
soon to install : "fixed" heads and a damn tune. Project snaked8 continues...
Fubarian is offline
