Forced lube mod done (with pics) need input - TCCoA Forums
post #1 of 7 (permalink) Old 02-10-2005, 07:03 PM Thread Starter
Hey guys, I did the forced lube mod per J.L.'s article on a 1992 SC AOD transmission.
I have a ton of aeroquip line left and decided to use that instead of hard line. Does anyone see a problem with this? Hopefully the aeroquip line will withstand the pressure.
Jeramie
92bird is offline
post #2 of 7 (permalink) Old 02-10-2005, 07:05 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
I thinks that's a great idea. Seems like it will be more durable when dropping/installing the tranny.
tinman_72 is offline
post #3 of 7 (permalink) Old 02-10-2005, 07:28 PM
used some expensive stuff there i have mine done also
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #4 of 7 (permalink) Old 02-11-2005, 04:19 PM
Very nice. What size line is that #4 or 6?
Heavy Metal is offline
post #5 of 7 (permalink) Old 02-11-2005, 04:57 PM Thread Starter
Its 4AN..
Can someone verify that I have this tapped into the correct port? Its the only port on the driver's side, per Jerry's article, however, this is an AOD, not a 4R70W.. So I just wanna make sure I have the correct port. Someone on SCCoA.com was telling me I hooked it into the wrong port.
Jeramie
92bird is offline
post #6 of 7 (permalink) Old 02-11-2005, 10:08 PM
Whining Intakes Rock
Al_Florida's Avatar
I looked at that and thought it was wrong too until I saw that you did this to a 92. I don't know AODs.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #7 of 7 (permalink) Old 02-11-2005, 10:29 PM
Well that port is unmarked. The 3 ont he other side say direct(goes to direct clutch circuit) TV(used for adjusting throttle pressure) and Forward which I would assume goes to the forward clutch circuit. I think you have the correct fitting, but you shoudl really get a manual on that transmission to be sure.
