What stall speed do you run? - TCCoA Forums
post #1 of 7 (permalink) Old 02-10-2005, 07:55 PM Thread Starter
My car is a stock 5.0 with an aod. I'm wondering if 2400 stall would be plenty. It brake stalls at 2200 with a supposed 1800 converter and its a dog off the line. Post your combo and how the converter makes it feel.
icantdrive55 is offline
post #2 of 7 (permalink) Old 02-11-2005, 11:38 AM
I run a 2800 in my 4r70w. It is going to get changed for a 3500 as soon as I change engines.
AOD transmissions are completely different from 4r70w transmissions. Every time I have seen someone install a real high stall converter(3000) into one the transmission did not last long unless it was rebuilt and upgraded. The direct clutches and OD band in them just can't keep up. My general recommendation for those transmissions is less than 2500 stall with direct drive deleted.
post #3 of 7 (permalink) Old 02-11-2005, 07:45 PM Thread Starter
I'm gonna see a bigger rpm drop with the 4r70w guts I'm installing. Figure if I can get the shift timing right and make the 3-4 shift not slide-bump it will last. Thing that scares me about a non-lockup is even normal 3-4 shifts break the shaft with a damper between the 2 shafts. No w.o.t. 3-4 shifts allowed. Once the two shafts are basically locked together something has to give if shift timing isn't perfect. 3rd gear still has 40% converter slippage factored in with a lockup converter, non lockup has full slippage for 3rd. Non lockup will be more durable then if I resist shifting into overdrive unless just cruising. Got a 28,000 lb plate style cooler and a new in the box valve body too [btw if anyone wants a brand new valve body for an aod they are $50.00 till they run out] Shouldn't have started buyin stuff maybe a Mazda 5 speed would be cheaper.
post #4 of 7 (permalink) Old 02-11-2005, 08:02 PM
Right now, 3200. Next month, 3600ish
Rich95XR7 is offline
post #5 of 7 (permalink) Old 02-15-2005, 08:19 PM
2500 right now, wanting more. Or maybe more gear. . . (have 3.73 now)
loudpedal99 is offline
post #6 of 7 (permalink) Old 02-16-2005, 12:07 AM
Warlockguitarman's Avatar
Send a message via AIM to Warlockguitarman Send a message via Yahoo to Warlockguitarman
i am trieng to decide on my stall speed, i was thinkin of the marauder, but maybe a 3200 or so, im worried about the traction that i will have. what stall would be best for a daily driver that sees some stop light runs and some drag strip runs, with 275 width street tires, pi swapped, 3.73's, and nitrous.
96 pearl white 4.6 tbird: rebuilt npi block with pi heads, pi intake, crower stage 2 cams, shm high lift springs, L-MAF, 3.73's, marauder converter, jmod, kooks headers, xpipe, no cats, 2.5 in exhaust, no mufflers, a dyno tune, lots of interior work, 1 in drop with lots of new bushings, 18 in rims. 279 hp 319 tq. curently running 13.9 at 101 mph with a 2.1 60 time in 100 degree weather while having some nasty spark knock. Soon to have higher stall, aftermarket intake manifold, weight reduction, and hopefully a nice shot of the giggle gas.
Warlockguitarman is offline
post #7 of 7 (permalink) Old 02-16-2005, 08:22 PM
Well I'm getting 2800 this weekend, at the meet in April you can ride in my car man.. Its gonna be J-Modded too! Tire size is 255s in rear / front.
1997T-Bird is offline
