Which Speedo gear? - TCCoA Forums
post #1 of 19 (permalink) Old 02-13-2005, 11:06 AM Thread Starter
miller1995's Avatar
Which Speedo gear?
Got 3.55's a few weekends ago and have been trying to figure out the correct speedo gear. The sccoa calculator says tan, the one already in there from the 3.27's, but after searching here seem JL says orange. I am leaning towards orange because the calculator doesn't seem to be accurate when stock numbers are put in. It says a blue gear but mine came with a green and says a green gear shoulda been used with the 3.27's. The 3.27's and speedo gear came from a 96 sport so I was running the correct tire size and everything for that set up.
Bryan Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #2 of 19 (permalink) Old 02-13-2005, 11:10 AM
I beleive orange is correct. How many teeth output shaft 7 or 8? what size tires?
post #3 of 19 (permalink) Old 02-13-2005, 11:24 AM Thread Starter
miller1995's Avatar
4R so 7 tooth output shaft, 3.55's, 26.6 (225/60/16's)
SOLD1998 Escort ZX2
post #4 of 19 (permalink) Old 02-13-2005, 11:46 AM
You need a 19 tooth tan speedometer gear. Unless you have an 8 tooth shaft which will require a 21 tooth purple.
post #5 of 19 (permalink) Old 02-13-2005, 11:54 AM Thread Starter
miller1995's Avatar
The trans is a 96 trans so it should be a 7 tooth drive. I'll have to check but I am pretty sure its has a tan one in there already.
Thanks Alan
SOLD1998 Escort ZX2
post #6 of 19 (permalink) Old 02-13-2005, 12:15 PM
No problem. Here is the calculator I use in case you need it.
http://home.att.net/~jroal/drive.htm
Actually I have a discrepancy in your tire size. those tires should not be 26.6 tall
If they are truely that tall you need the tan gear if they are shorter you need the orange gear.
post #7 of 19 (permalink) Old 02-13-2005, 12:29 PM Thread Starter
miller1995's Avatar
The tires are kelly chargers. When I went to their site it says 26.6 as tire height.
-Miller
SOLD1998 Escort ZX2
post #8 of 19 (permalink) Old 02-13-2005, 12:31 PM
Can you measure them yourself?
post #9 of 19 (permalink) Old 02-13-2005, 12:49 PM Thread Starter
miller1995's Avatar
I guess if you want I could get out from in front of the computer and walk out in the cold rain with my tape measure
EDIT: Raining harder than I thought, think I will wait a few. What number did you get?
SOLD1998 Escort ZX2
post #10 of 19 (permalink) Old 02-13-2005, 01:14 PM
I just punched it in by the tire dimensions and compared that to trying it by tire height. They did not match.
post #11 of 19 (permalink) Old 02-13-2005, 01:29 PM Thread Starter
miller1995's Avatar
I got a .6 difference in number of teeth. 19.3 vs 19.9
SOLD1998 Escort ZX2
post #12 of 19 (permalink) Old 02-13-2005, 02:07 PM
Darrin's Avatar
Sorry to hijack, but GOD I hope people read that thread Alan quoted from and come here to ask about Dennis.
Darrin is offline
post #13 of 19 (permalink) Old 02-13-2005, 04:03 PM
Me too the 19.3 calculation would make the tan (19 tooth)gear closest. The 19.9 calculation would use the orange (20 tooth) gear.
post #14 of 19 (permalink) Old 02-23-2005, 04:47 PM
With 3.27's, 215/70R15, 8 tooth output, it looks like I'd need a purple 21 tooth gear, correct?
Best times:
Cougar281 is offline
post #15 of 19 (permalink) Old 02-23-2005, 05:12 PM
I got 20.7 so 21 would be the closest
post #16 of 19 (permalink) Old 03-16-2005, 09:02 PM Thread Starter
miller1995's Avatar
Ok finally got around to switching gears. I had a 19 tooth tan gear in the trans like I thought and went to the orang 20 tooth gear. While traveling with Tydlwavs and Blacktbird96 they both were going 60 in their Foci while I was at 58 or so mph. Should I go back down to the tan gear?
-Miller
SOLD1998 Escort ZX2
post #17 of 19 (permalink) Old 03-16-2005, 10:54 PM
ITT-BIRD's Avatar
Subscribe..... need to get purple 21 when come off boat.
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
post #18 of 19 (permalink) Old 04-12-2005, 08:55 PM
ITT-BIRD's Avatar
Speedo Gear Part Numbers
ITT-BIRD is offline
post #19 of 19 (permalink) Old 04-13-2005, 12:15 AM
Two things:
According to my calculations, a 225/60/16 tire should be 26.6299 inches tall.
225/25.4 = 8.858
(section width/millimeters per inch) = 8.858
8.858x.6x2 = 10.6299
(8.858 x aspect ratio x two sidewalls) = 10.6299
10.6299 + 16 = 26.6299
(10.6299 + wheel diameter) = 26.6299
Hope that made sense.
Now, my question is, how do you know whether you have the 7 or 8 tooth speedo drive gear? For instance, which gear would a 94 Mark 8 have? Is there a list of which transmissions have which gear?
-Rod
