Driver's side rear wheel wobble - TCCoA Forums
post #1 of 7 (permalink) Old 02-14-2005, 05:02 AM Thread Starter
Hi All,
My son’s 1994 Thunderbird rear wheel (driver’s side) is making a thump noise when driving.
I jacked up the car to find that the wheel has play in it, a lot of play. Is this the wheel bearings in the hub assy?
If so do I need to remove the hub and have the new bearings pressed in? Is it difficult to remove the hub?
I need to fix this soon, he need’s his car for work and school.
Thanks in advance.
-quadcells
quadcells is offline
post #2 of 7 (permalink) Old 02-15-2005, 04:17 PM
You might want to make sure it's not some other part in the rear suspension. When I bought it, both rear wheels in my SC could be moved a good 1/2". It made the thumping sound you mentioned. The problem was the bushings in the rear upper control arms. The wheel bearings were fine. With the rear wheel off the ground, have someone lift up on them and watch for movement in the control arm bushings.
Black 94 SC
Black 95 SC
Black94SC is offline
post #3 of 7 (permalink) Old 02-15-2005, 04:26 PM
Cool
yea, that's true. Doesn't necassairily need to be the bearings, but if it does turn out that they are bad, the hub will have to be replaced. The bearings aren't servicable in the hub. I had mine done not to long ago, it was about 69.00 for the hub and about 80.00 labor.
Uncaged 94 is offline
post #4 of 7 (permalink) Old 02-15-2005, 08:29 PM
TCCoA Founder
Sir William's Avatar
I paid $15 shipped for a used hub. $32 for the bearing. $15 at the Ford shop to have it pressed in.
Word of caution, don't let ANYBODY but Ford try to press in the new bearing. Ford garages have a special set of dies just to press the hubs & bearings on our cars. They were all required to buy them. But if you'll pull the rear carrier(s) off the car yourself and take them in, they'll likely press them for you for next to nothing. Good luck.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #5 of 7 (permalink) Old 02-15-2005, 08:51 PM
Cool
That's a good deal, probably the way to go if you can pull the works yourself. I can't though, because of my back, so I'm stuck paying a lot more money than you Yuts!!
post #6 of 7 (permalink) Old 02-17-2005, 05:11 AM Thread Starter
Thanks people,
But I had to bring it in to get service. I try to do as much as I can but this time I didn't have the time and the shop wants $400.00 to do it.
The hub was destroyed by the bad bearings and took a long time to remove.
The shop ordered the parts from Ford and it should be done today. I was surprised by the size of the bill.
Thanks again for your help.
-quadcells
post #7 of 7 (permalink) Old 02-17-2005, 05:21 AM
Hey now I have the hub tamer.
