Transmission doesn't want to downshift... - TCCoA Forums
post #1 of 20 (permalink) Old 02-15-2005, 07:42 PM Thread Starter
ThunderONWheels93's Avatar
Unhappy Transmission doesn't want to downshift...
Hey guys, just registered here, just wanted to say whats up. Got a question about my bird too. The transmission doesn't seem to like the "passing gear". When I put the pedal to the metal, it should shift into the 1st gear, it used to, but now it shifts into the 2nd instead of the first, and sometimes it doesn't even do that. This isn't a bad problem really, maybe something is just unplugged? Thanks.
ThunderONWheels93 is offline
post #2 of 20 (permalink) Old 02-15-2005, 08:27 PM
Check the tranny fluid level and see if it is low.
whitecoug is offline
post #3 of 20 (permalink) Old 02-15-2005, 08:57 PM Thread Starter
I did when the problem first started happening and it seemed fine, maybe I have to change it?
post #4 of 20 (permalink) Old 02-15-2005, 09:11 PM
I would try a flush and new filter. Start out cheap. . . . . .ok cheap-ish!
RAYBROADWAY is offline
post #5 of 20 (permalink) Old 02-15-2005, 09:12 PM
Hughges's Avatar
Send a message via MSN to Hughges
If I'm not mistaken don't the 5.0's have an AOD and wouldn't a misadjusted Throttle valve cable make it not shift right? Please correct me if I'm wrong.
International Harvester all the way!
Remember: Nothing runs like a DEERE, and nothing dies like one either! LOL
Hughges is offline
post #6 of 20 (permalink) Old 02-15-2005, 10:02 PM
Exactly it probably had a broken grommet. Fix it immediately or you will fry the transmission. The part costs about 50 cents.Look at the cable where it conects to the throttle body there is a little plastic grommet on it that the cable connects into. They are prone to breaking and giving problems like you are having. That cable doesn't just control passing gear it controls line pressure in the entire transmission.
post #7 of 20 (permalink) Old 02-16-2005, 01:34 AM
And here's how to check the line pressure and what measurments
the tool has...
www.mn12racing.com/docs
Hope it helps...
//Per
Thyg0d is offline
post #8 of 20 (permalink) Old 02-16-2005, 07:47 PM Thread Starter
What does this "grommet" look like? It seems like that is the problem because my transmission is fine.. heck , be nice just to get a new throttlebody..
post #9 of 20 (permalink) Old 02-16-2005, 08:04 PM
thunderbirdlver's Avatar
Send a message via AIM to thunderbirdlver Send a message via Yahoo to thunderbirdlver
i have done the tranny fluid and filter change. but how do u flush it? but about the tv cable......i got a new tranny in and it sometimes would shutter really bad when u took off. i think it was stuck in second. it didnt act right at all. here the tv cable was just dangling there. once i adjusted it i couldnt believe how great this tranny was. better than the factory one. that would b my guess too. does it hurt to adjust them all the way up? it shifts nice and firm but i didnt know if it could damage it.
If your exhaust tip is larger than your cylinder bore, then you are a Ricer.
thunderbirdlver is offline
post #10 of 20 (permalink) Old 02-16-2005, 08:38 PM Thread Starter
OK, i think im confusing myself. The throttle valve cable attaches to the throttle body right?
post #11 of 20 (permalink) Old 02-16-2005, 09:26 PM
yes that will fry the transmission. They are picky you have to adjust them with a pressure guage and a precision gauge block.
post #12 of 20 (permalink) Old 02-16-2005, 09:33 PM Thread Starter
Can one of u guys give me a pic of the throttle valve er whatever just so im clear about what you are talking about, im a n00b but im learning as I go about these engines, this is my first car btw.
post #13 of 20 (permalink) Old 02-16-2005, 10:02 PM
I would but I refuse to own another aod car unloess it's really nice and cheap. Then i'll convert it.
post #14 of 20 (permalink) Old 02-16-2005, 10:27 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
on the 5.0 H.O, the throttle linkage is on the backside of it. Look at the linkage and I believe it is the bottom cable. It looks like a cable with a spring on it, with a notched part sticking out the end of it past the grommet and a small square piece where it plugs into the grommet. It should snap into a grommet on the linkage bracket of the throttle body. They get old and brittle and break into little pieces. Since this is the only thing that is controlling the transmission and tells the tranny what the line pressure is, you will fry up your tranny in no time with it disconnected.
-Thomas
Thomas is offline
post #15 of 20 (permalink) Old 02-17-2005, 04:50 PM Thread Starter
Mine is connected.. i guess its just screwed up, maybe i'll just get a new throttle body...
post #16 of 20 (permalink) Old 02-17-2005, 04:53 PM
Why would a throttle body help?
post #17 of 20 (permalink) Old 02-17-2005, 04:56 PM
Hughges's Avatar
You shouldn't buy a new throttle body. You should just get the TV cable adjusted. It would cost way less and buying a new throttle body won't fix the problem.
Hughges is offline
post #18 of 20 (permalink) Old 02-17-2005, 09:43 PM Thread Starter
Oh ok. Well, since im gettin new brakes next week, i'll ask them to take a look at that too.
post #19 of 20 (permalink) Old 02-18-2005, 02:44 AM
Okay, I don't know if you understand how expensive it can get if
your line pres. isn't exactly correct?!
It cost me around 2600 bucks to get mine working again!!!!!
So don't drive AT ALL 'til you get this checked...
My line pres. was 32 PSI and that was enough to fry it pretty quickly
and if you don't have anything adjusting your line pres at all
you'll fry every little clutch within 100 miles.... If not faster...
But I guess it's up to you...
//Per
Thyg0d is offline
post #20 of 20 (permalink) Old 02-18-2005, 05:44 PM Thread Starter
OK! finally know what the throttle valve cable is/looks like.
