Trans swap - 2000 into 1995 - Differences? - TCCoA Forums
post #1 of 4 (permalink) Old 02-16-2005, 09:21 AM Thread Starter
We're picking up a 2000 Mustang GT Trans to put in my buddies 1995 Thunderbird tonight.
I need to know, what are the differences? What do i need to change?
Do i just need to move a couple of pins, or do i need to buy any electric parts from inside the trans? Should swap any of the old electronic parts into the new trans? I've heard numerous references to re-pinning the connector, but haven't come across a picture or a clear explanation of what i need to change. I could probably figure it out, but if someone can point me to some directions or a pic, i'd appreciate it.
I read somewhere that there might be a different number of teeth on the output shaft. What speedo gear should i use with 4.10's, or will we need to get a speedcal?
Dave
sleeper_dave is offline
post #2 of 4 (permalink) Old 02-16-2005, 09:36 AM
Re-pin the harness, swap the MLPS Lever, MLPS Sensor, TCC Solenoid, swap his VSS sensor to the new transmission. I think that covers all that needs to be done... You could also do the JMod while you have the new one out...
Harness info
Best times:
Cougar281 is offline
post #3 of 4 (permalink) Old 02-16-2005, 10:10 AM
Have the c-clip for the OWMD welded if he plans to spin that trans. into the higher RPMS a lot. Add at LEAST a 24K stacked plate transmission cooler. I'd go w/ 28K personally. $60 from Summit for a B&M.
300HP drill spec J-Mod
Don't forget to fill the new trans with Mercon V fluid, not Mercon III.
Have lots of rags around (trust me)
Jay
FordMan77 is offline
post #4 of 4 (permalink) Old 02-16-2005, 10:21 AM Thread Starter
He's already got a tranny cooler. The old trans didn't actually blow, just started leaking real bad, but we'll flush it out good anyway.
We're not messing with the seperator plate, not for awhile anyway. It's going right back to Alternative to get the tune finished when it's done, and it's a 2k trans, so i don't see a need for the j-mod. I've never heard of this welding thing... what is it? You're talking about something on the OWC? I've spun my stock (j-mod, tune, tc) '97 trans to damn near 7k many, many times, so i'm not really worried about putting a 2k trans behind a stock '95 SOHC motor.
Oh, believe me, i know about the rags. Gonna have plenty of oil dry handy too. Always fun stuff. I've done this job a few too many times already (helped do trans's in '89 SC, '95 Mark, '95 t-bird, and did it myself in my '97 mark... twice when i screwed up).
Thanks for the help guys!
