IRS Diff - TCCoA Forums
post #1 of 5 (permalink) Old 02-17-2005, 02:41 AM Thread Starter
BlueSteelBird's Avatar
IRS Diff
Will the cobra IRS Diff's bolt directly up to an mn12? I have found several bare ones that are aluminum and since I cant buy the FRPP pumpkin anymore i wanted to just build one of these instead.
BlueSteelBird is offline
post #2 of 5 (permalink) Old 02-17-2005, 03:12 AM
Chapter Director Coordinator
jamesD's Avatar
99 and 2000 will, i think the 01s will as well
the 03+ will bolt in i believe, but have 31-spline side gears whereas we have 28-spline axles
jamesD is offline
post #3 of 5 (permalink) Old 02-17-2005, 07:33 AM
96bird's Avatar
Only the '99 will work. The rest, '00R, '01, '03, '04 cobras are 31 spline on the inboard stub, and of course like suggested you can change out the side gears to 28 spline.
96bird is offline
post #4 of 5 (permalink) Old 02-17-2005, 11:20 AM
The easiest way will probably be to get a Mark VIII aluminum pumpkin, a traclok carrier, and gears of your choice and have it assembled.
SloMo228 is offline
post #5 of 5 (permalink) Old 02-17-2005, 02:15 PM Thread Starter
thanks for the info
