Which Speedcal do I need? - TCCoA Forums
post #1 of 13 (permalink) Old 02-27-2005, 06:39 PM Thread Starter
I have a 96 tbird with a 01 gt tranny.. Which speedcal do I need?
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #2 of 13 (permalink) Old 02-27-2005, 07:32 PM
The Great Obucina's Avatar
did you pull the VSS out to see it is has the plastic gear?
if no plastic gear.......there is only one "Speedcal" www.dallasmustang.com
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 13 (permalink) Old 02-27-2005, 08:50 PM
Whining Intakes Rock
Al_Florida's Avatar
model # 9910
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #4 of 13 (permalink) Old 02-28-2005, 05:16 AM Thread Starter
how sure are you on that?
2004 F150
KrAzyT is offline
post #5 of 13 (permalink) Old 02-28-2005, 07:45 AM
Eleventeenth Gear Poster
Aaron K.'s Avatar
Probabaly the same one you needed when you asked this same question last week
Sold = 96 Thunderbird
Aaron K. is offline
post #6 of 13 (permalink) Old 02-28-2005, 01:37 PM
Al_Florida's Avatar
They only have 2 versions of the speedcal. 9910 and the 9910er. The er is for extended range. Reading the description of the 9910er:
"USE THIS SPEED-CAL WHEN INSTALLING A 99-2003 5-SPEED OR 6-SPEED MANUAL TRANSMISSION INTO A 1996-1998 MUSTANG."
Forgetting the part where it says mustang, are you installing a 99-03 5-speed or 6-speed manual transmission or a 4r70w automatic? We assume you are installing an automatic so you need the 9910 model.
# 0 rows returned
post #7 of 13 (permalink) Old 02-28-2005, 02:04 PM
Darrin's Avatar
MIAFD Performance
LOL, I like that
Darrin is offline
post #8 of 13 (permalink) Old 03-03-2005, 10:46 PM
ITT-BIRD's Avatar
OK what plastic gear. My tranny only had the plug blocking vss, my vss sensor has the plastic gear. So speedcal is not my only option? What plastic gear would i have to get.... the purple? For now im staying with my 3.27s but will most probably go with 3.73s this summer. Then id have to get a speedcal for sure or not; another plastic gear?
Im trying to do cheaper first because have some drivetrain mods planned in a few months. Hopefully re-replacing tranny is not one of them.... think i cleaned cooler well enough.
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
post #9 of 13 (permalink) Old 03-03-2005, 11:00 PM
I was told by many people that when I put my 3.73's in, I would need a speedcal to keep things in order with the 99 Tranny and so forth. Then I was told I may be able to use the WHITE Jeep 21 or 23 tooth speedo gear ( I dont remember exactly with tooth it was, but there is only one white one.) If I remember correctly this is because of the differences of the 7 and 8 tooth output shaft.
Well, I bought the speedcal and never installed it, I used the Jeep speedo gear and it worked fine for the 3K or so I put on the car so far.
But remmeber the gear is not recommended by everyone, because it may break, then you'll need a new one and again.
Dave
DMcBrideBoston is offline
post #10 of 13 (permalink) Old 03-05-2005, 06:34 AM Thread Starter
there cheap anyways.. i think ill pick one up for now.
2004 F150
KrAzyT is offline
post #11 of 13 (permalink) Old 03-05-2005, 07:53 AM
The 23 tooth gear will break, it's only a matter of time.
post #12 of 13 (permalink) Old 03-05-2005, 09:08 AM
Darrin's Avatar
Yeah, just get a speedcal and do it right the first time.
Darrin is offline
post #13 of 13 (permalink) Old 03-05-2005, 03:08 PM
ITT-BIRD's Avatar
OK ... the speedcal calculator shows speedo gear teeth ... we have stock 19 right? But it doesnt say anthing about 7 or 8 tooth output shaft ... how do you go about calculating the binary for this?
Use 21 tooth to get difference in OS then use speedcal to compensate for gears?
ITT-BIRD is offline
