THE Automatic vs. Manual Transmission Thread - TCCoA Forums
post #1 of 30 (permalink) Old 03-01-2005, 02:50 PM Thread Starter
Talking THE Automatic vs. Manual Transmission Thread
Ok:
Rule Number 1: Keep it civil
Rule Number 2: Provide facts and/or personal observations (or at least well documented information)
Soooooooo which is better, and automatic transmission (4 speed), or a manual transmission (5/6 speed)....AND why!!
For the following applications (in an MN12/FN10):
Drag Racing 1/4 mile
Road Racing Road course (not SCCA)
Overall Performance Highway (mpg), Drag, Road, Top end, etc.)
I’ll start off:
Drag Racing IMHO, tough call! If the car can be setup to hook properly I would say manual. But the driveline shock can often limit traction. And without a “bleed down” clutch, sometimes controlling the clutch slip will decrease consistency. As will differences in shifting from run to run. On the flipside, the automatic is a lot “nicer” to the driveline and is easier to hook up. But it is limited by the lack of gears and thus the engine won’t stay in its power band as much as a manual. But the auto can shift faster (usually) than a manual so what may be lost in gears might be gained in shift delay. (A caveat: I am not a drag racer, so for me, this answer is more opinion than fact)
Road Racing Manual: More gears will let you stay in the “power band” more than with the automatic and with the clutch you can better control the driveline shock while coming out of a curve. Whenever I lived on windy back roads, I always had better performance through the curves with a manual than with an automatic.
Overall Performance Manual: More gears, less driveline loss, more durable (if not abused), and cheaper repair/replacement. I have converted a number of cars (mainly TC’s or Mustangs) from automatic to manual and in EVERY case I (or the person I did the swap for) was very pleased with the swap.
So, thoughts, opinions, etc.
And remember rules one and two.
69 F100 LWB w/460 Engine
post #2 of 30 (permalink) Old 03-01-2005, 04:16 PM
Like Titles Matter
kdanner's Avatar
Originally Posted by 94 Daily Driven 4.6L
Ok:
I’ll start off:
Well I pretty much disagree with all of that. The driveline shock at the dragstrip comment is incorrect, driveline shock is good, it works the chassis. Any traction problem caused by that is a suspension or tire problem, not a transmission issue. I highly disagree with the lack of gears and staying within the power range. If you look at a 4R70W compared to a 5 speed manual the 4R70W should actually be much better at this when calibrated properly. With the ability to lock the converter in 3 gears(or even all 4 if you use the right EEC) this gives effectively 7 forward gear ratios compared to 5. The 4 unlocked ones are variable due to the slip of the converter, allowing proper converter selection to also further contribute to staying in the proper RPM range, something a manual trans cannot do without slipping the clutch. I also disagree with the shifting faster, a purpose built drag race manual transmission also maintains constant power flow just like an automatic, there should be not even a microsecond of power not going to the wheels with either.
Road racing: see the forward gear ratio comments above, this is the same.
I don't buy the durability arguement, and certainly not the cost arguement. Cost for a quality flywheel, pressure plate, clutch, and bellhousing will far exceed the cost of a quality torque converter every single time. Again here, automatic trans calibration and converter selection is key to making them perform, and most people flat get it wrong.
There is some merit to driveline losses due to additional inertial losses and frictional losses found in an automatic. However these are greatly reduced in modern automatics compared to the older gereation ones, making this gap smaller and smaller.
kdanner is offline
post #3 of 30 (permalink) Old 03-01-2005, 04:25 PM Thread Starter
I agree with everything you said. I should have clarified the question a little bit. When I was thinking about this I was thinking more along the lines of "stock", or "slightly" modified transmissions. i.e no TC lock up in 3rd gear, no racing manuals, etc.
And I had completely forgot about the price of all the "clutch" parts. So then the durability of the clutch is also a negative.
But if we're talking about mainly "stock" applications, do you still disagree?
post #4 of 30 (permalink) Old 03-01-2005, 04:41 PM
Jimbobicus's Avatar
Send a message via AIM to Jimbobicus
Just thought I'd toss in my 2 cents here.
I swapped a T5 out of a 82 Mustang into my bird a year ago. Aboslutely the best thing that's ever happened to my car why Ford wouldn't give us a manual with the V8 to begin with is beyond me.
Driving my car is fantastic. Double-clutching on the downshift and stomping it coming out of the corner... wow... it's a rush. For me one of the biggest benefits is being involved in what the car is doing. With the auto you just mash the pedal and see what happens. It take some skill to operate a manual efficiently and effectively, so there is a sense of accomplishment that is an added bonus.
I agree with most of the comments made about the auto for drag racing. There is a reason that until you get up to Pro Stock level stuff they are all using a GM TH400.... A very good transmission BTW.... anyhoo, I've got to get to class....
Jimmy
1993 Thunderbird 5.0
Dual exhaust - no cats - Flowmaster 40 series mufflers
T5 - Aluminum flywheel - Stage II clutch
1990 Thunderbird SC
All stock... For now...
Jimbobicus is offline
post #5 of 30 (permalink) Old 03-01-2005, 04:49 PM
Auto's are definately more user friendly.
For instance aod's are crappy transmissions (everybody agree?)
Alot of people claim T5's are good transmissions(not me I hate them)
Now go to the track and watch the fox body's run. Even the guys with stock aod's have better luck at keeping them together than the guys with t5's. Yet the T5 can handle more torque. Why because missing a shift in a t5 will break it . Auto's don't break like that most of the auto issues come from overheating. Unless you are JL who broke a mechanical diode.
Don't get me wrong manual transmission have benefits. I wouldn't think about putting an A4LD in my ranger, it just doesn't have enough torque.
Auto's are more consistant than manuals for drag racing as well. On a road race scenario I would probably suggest a manual transmission for the benefit of engine braking. For overall performance I would suggest a modern lockup overdrive transmission.
post #6 of 30 (permalink) Old 03-01-2005, 08:22 PM Thread Starter
One thing I thought about as I was reading these posts is this: Why are the manual transmission cars almost always faster (i.e. 1/4 times) from the dealership (bone stock)?
For example, the Fox Mustang, the Camaro, the Vette. All the manual transmission cars are faster. Is it that the EEC tune is lower so the automatic will "live" or is it something else?
post #7 of 30 (permalink) Old 03-01-2005, 08:56 PM
Like Titles Matter
kdanner's Avatar
This really relates to my comments about newer autos versus older. I think the more appropriate question is "why were" they quicker, not "why are", as the difference is almost nonexistant anymore. The new Mustang auto runs very comparably to the manual. You could say the same for LS1 cars. Put a good converter in either and the difference is pretty much nothing. Now, you might say, it isn't stock, you changed the converter. I see it different. Yes I changed the converter to get more slippage, this put me into the ideal power range quicker, much the same as slipping a manual trans clutch. If you look at what I consider to be the last bastion of real sportsman drag racing, NHRA/IHRA Stock and Superstock eliminators, invariably you'll find the auto trans combinations to be quicker than the same combination with a manual trans. Now the engine combination being the same means no appreciable power difference between 2 cars, we know the less efficient auto puts down more at the wheels, but yet the car still runs faster. Why? Two reasons pretty much. First, different trans gear ratios than stock via a custom planetary, shifting the 1st and 2nd gear ratios a good bit higher, which makes them closer ratio, allowing the engine to be operated in a narrower range due to far less RPM drop between gears. Now the manual trans cars do that too of course. But, second, proper converter selection has kept the RPMs in the ideal range for a longer time during the pass than the stick car can, thus making up for the increased parasitic loss, and then some.
kdanner is offline
post #8 of 30 (permalink) Old 03-01-2005, 09:00 PM
The only advantage useing a stick shift in one of our cars is that you no longer require a stock EEC to run the tranny, therefore can go with an aftermarket stand alone computer/fuel injection system that would make it easier to get power out of, but also highly illeagal....
Leland Jacobson is offline
post #9 of 30 (permalink) Old 03-01-2005, 09:07 PM
Yeah but a manual is so much more fun to drive. And it's always in the gear you want, unlike an auto which takes a second to find the right gear.
SloMo228 is offline
post #10 of 30 (permalink) Old 03-02-2005, 12:07 AM
94TchikinV8's Avatar
Send a message via AIM to 94TchikinV8 Send a message via Yahoo to 94TchikinV8
When built right, autos can be more consistent and just as fast, if not faster, than a manual, but I'd take a manual over an auto any day of the week. I like to shift my own gears, it's a lot more fun. That is good info from 94DD and kDanner by the way.
1994 Thunderbird LX V8
Still in pieces in the garage awaiting body work, paint, and a drivetrain...
Currently driving a 98 Mustang GT convertible:
02 Explorer engine, Comp 262ah cams, Steeda underdrives, aftermarket H-pipe with high flow cats, SLP LM1 exhaust, MGW shifter, RAM clutch
[email protected], 2.17 60ft(stock 2.73s, worn-out trac-lok)
94TchikinV8 is offline
post #11 of 30 (permalink) Old 03-02-2005, 01:30 AM
Jimbobicus's Avatar
Amen and amen.
1990 Thunderbird SC
post #12 of 30 (permalink) Old 03-02-2005, 07:08 AM Thread Starter
Agreed, and that seems to be the a reoccurring theme... the auto (when set up properly) is as fast (if not faster) than a manual... but "I'd rather have a manual".
Is it the “fun factor” and “being more in control” of the car (or at least feeling like you’re in control more)? I too much prefer a manual vs. an auto. Personally, my major “gripe” with an auto is the “delay” before things happen, and the spacing of the gear ratios (or the lack of gears in general).
And what kdanner said about the "why are" vs. "why were" is dead on. I think now with the computer control, lock up TC's, 4/5 speed automatic transmission, the autos are right up there with the manuals.
post #13 of 30 (permalink) Old 03-02-2005, 08:15 AM
Amen to that. Whenever I stomp on it in a friendly test of acceleration, I lose a little bit of time as the thing downshifts first to 3rd then to 2nd.
SloMo228 is offline
post #14 of 30 (permalink) Old 03-02-2005, 08:22 AM
Back in the day, around 1965-66 my buddy built a '40's Willys Coupe for the drags. He put a 401 Buick engine in it with a turbo-hydromatic not a stick. I asked him why. He said "consistency" and explained:
When the Mustang first came out, he and his brother ran down to the dealer and bought identical Mustangs. Both were 289's, both identically equipped (even the interior and exterior colors), except for the the trannies. My friend's was an auto, his brother's a stick. At the time their family owned Westhampton Drag Strip and from the time they were little kids, both brothers had spent lots of time at the track and had owned, built and raced lots of different cars over the years, so they were pretty experienced drivers. Brand new out of the box, they raced the mustangs side by side many times, even swapping drivers, and the auto beat the stick shift consistently. Now true, the stick had a stock shifter and clutch, but the auto was not modified either and had a stock converter. Neither brother could manually shift the cars as smoothly or consistently as the automatic could, and this way before the day of the EEC controlled automatic. Apparently the time lost in shifting the manual outweighed the HP advantage through the drive train. I always thought that was interesting.
By the way, the Willys did pretty well... he just couldn't keep the front wheels on the ground. He drove it on the street and used to challenge passengers to change the radio station. When they reached out to hit the pre-set he'd hit the gas and send them back into the seat. I tried and couldn't my hand within 6 inches of the dash... fun car..
You gotta be careful comparing track times published for "identical" cars with manual and auto transmissions. My automatic vette came equipped with a 2.72 rear end, I don't know off hand what rear the 6-speeds have, but I know they're lower than 2.72.
-mike
96 GoldBird
N/A:
96 GoldBird is offline
post #15 of 30 (permalink) Old 03-02-2005, 08:35 AM
Johnny Five is Alive
WkStill's Avatar
Send a message via AIM to WkStill Send a message via Yahoo to WkStill
My opionion:
Drag : 2 speed Chevy Powerglide
Road Racing: No Experience on this, Depends on # of turns I would say.
Highway: 5 Speed Manual (less wasted energy)
1984 Merc Cougar
5.0L, GT40X HEADS, E303 CAM,X303 Valvetrain
1998 4R70W Controlled by Baumannator TCS., 3.73 Track Lock Rear., Bauman Lev 3 Shift Kit.
190LPH, 67mm EGR, 65mm TB, 73mm C&L MAF, 24lb/h Inj, TwEECer RT, A3M EEC-IV
TCCoA-AHole Crew 2004
Disclaimer: The opinions expressed in my posts are my own. They are not meant to start a flame war or discourage people. Just my honest opinion and nothing more
Just great, 4 mores years of GOP crap, Im republican, and I endorse this message
WkStill is offline
post #16 of 30 (permalink) Old 03-02-2005, 09:33 AM
On Probation
blown96bird's Avatar
transmissions
This is my personal oppinion.
1. I feel that a automatic is better for drag racing because of more consistancey
and less stress on the drivetrain. A manual can be faster if you powershift it
but most people can not and if done offten it substanialy shortens the life of
the driveline.
2. I feel in road racing a manual is perfered for a few reasons and here they are.
A automatic transmission would probly over heat from the abuse constant full
throttle runs and up and down shifts. A manual is perefered because theres is
no unexpected up or down shifts in a turn which could upset the car.
I feel over all a automatic is perefered except in lowered powered application where a 4 cilinder engine is used. The reason for this is that a automatic consumes a fair amout of power that most 4 cilinder can't afford to lose and because of the extra power consumed the fuel encomny is reduced becaue of the engine having to work harder.
blown96bird is offline
post #17 of 30 (permalink) Old 03-02-2005, 10:13 AM
bowez's Avatar
Yall forget a auto comes from the factory for smooth shifts (hence need for the J-mod).
So IMO to compare the two the auto needs to be spitting out as firm shifts as the manaul does.
Now compare a Electronicly shifted auto (4R or similar where you can manaully run the gears if you want) I'd say is the best all around.
And gears is no longer an issue for we now have 6speed Autos from the factory. Plus the fact of aftermarket overdrive add-ons.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #18 of 30 (permalink) Old 03-02-2005, 06:17 PM
There's also electronic control systems for transmissions that allow you to shift at the touch of a button. But for some reason, the manual is just more fun.
SloMo228 is offline
post #19 of 30 (permalink) Old 03-03-2005, 08:22 PM
Gawsh, I want a Turbo 400 with a clutch I knew a guy had a 8-71 on a Hemi with one in his t-bucket. He coulda got by with a slipper clutch and no tranny in that thing
icantdrive55 is offline
post #20 of 30 (permalink) Old 03-03-2005, 10:22 PM
The Great Obucina's Avatar
that can be fixed....J can "modify" the 0s and 1s to do that
joseph
"Booyah". Stu Scott.
The Great Obucina is offline
post #21 of 30 (permalink) Old 03-04-2005, 02:56 PM
rustyul's Avatar
Well, some here have already said, the 5-speed is much more fun to drive. I like the percieved control of a manual. Driving my 4.6 Auto versus the 3.8 SC is night and day, even with similar HP numbers. For drag racing though, with a stock clutch setup (brand new) I have a very difficult time finding the right touch to keep the wheels from spinning on the SC. Seems to me (haven't driven and auto SC) that an automatic would be quite a bit easier to keep traction.
Glen "RustyUL" Weldon
95 Thunderbird LX - 4.6
rustyul is offline
post #22 of 30 (permalink) Old 03-04-2005, 03:16 PM
joshbea6's Avatar
I like being able to down shift to whatever gear that I want to pass/ corner, etc, and NOT have to wonder about which gear the auto is going to be put in.
I also like the fact that the 5 spd birds did NOT have the governor.
If I was getting a car for just driving around.....I'd still ONLY get a manual tranny, unless I had NO other choice
joshbea6 is offline
post #23 of 30 (permalink) Old 03-04-2005, 06:18 PM
the driveline.
on this one;
I drive a RX7 Five Speed as a daily driver every day and let me tell you, you people who say driving a stick is fun, you're out of your friggin minds especially if you work at a job that's dependant on labor...
EPelezo is offline
post #24 of 30 (permalink) Old 03-04-2005, 07:01 PM
motor city poster
Red96Bird's Avatar
ok my experience with autos vs stick,
i like the manuals in the fact that, ok when in gear-increase rpm to increase speed-no slipping, and i like the shorter gear ratios, ( i want a 5 spd in my bird because i hate the weak second gear that goes all the way to almost 80 mph) and direct drive, no wasted power through torque converters and such, sloppy *** factory shifts.
ok and then autos- when modified i love how they bang into the gears, chirp the tires, but that can be done with a manual too, but under acceleration i find it stupid, just keep the rpms at 2,000 and the car accelerates due to the slipping in the torque converter/non direct drive. while as i said before in the manuals, to increase speed, increase engine rpm
there is days i would love to have a stick just to mess around with, because i know with they way i drive somedays my auto will/does get hot and it will eventually kill it. but give me a stick in rush hour traffic, id pull over and wait for an hour or so. so i guess it all just comes down to personal opinion.
Red96Bird is offline
post #25 of 30 (permalink) Old 03-04-2005, 07:09 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
drag racing: auto
road racing/autocross: manual
fun factor: manual by far
overall drivablity: auto. for those times when you dont feel like shifting, smoother ride, etc.
i personally cant wait to buy a car with a manual trans.
in regards tot he questin about why manual cars run faster fromt he factory. most of the difference is in the 60 ft. i have a friend that had a 03 mach 1 auto with a few mods and ran 13.4 on street tires with a 2.2 60 ft. i have another friend with a 04 mach 1 5 spd thats was pretty much stock and he ran 13.1 on drag radials with a 1.7 60 ft. now the ato launched at around 2000 rpms cuz thats where the stock converter stalls at. the 5 spd launched at 4800 rpms because he can. put the drag radials and a 4800 rpm stall converter in the auto and its a whole different story. give the auto the 1.7 60 ft and it with be a 12.5-12.7 car all day.
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #26 of 30 (permalink) Old 03-04-2005, 07:11 PM
Oh and people get pissed when you downshift to pass or when you shift at 4k rpm on a 9k RPM engine and think that you're driving too fast...
- Pelezo
EPelezo is offline
post #27 of 30 (permalink) Old 03-09-2005, 01:45 AM
Moderator & Teksid Whore
guitar maestro's Avatar
Originally Posted by fdawg97lx
now the auto launched at around 2000 rpms cuz thats where the stock converter stalls at.
really? i made the same converter stall to 2400ish in my car
i would think it would stall to at least 2400 in the Mach...or am i missing something?
guitar maestro is offline
post #28 of 30 (permalink) Old 03-09-2005, 09:55 AM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
convertes stall differently behind different motors. same reason a mark 8 will stall at around 2k but put it in a bird and its around 2300-2400.
Frank
2007 Dodge Ram 1500
Previous Rides:
post #29 of 30 (permalink) Old 03-10-2005, 08:42 PM
Resident redneck
redneckcougarguy's Avatar
Send a message via AIM to redneckcougarguy Send a message via MSN to redneckcougarguy
drag racing: auto
Frank
i have to agree with frank on this one, except for overall, because automatics leave me with nothing to do and make me less aware as to what im doing.
and the fact that i live for roadracing more than anything might have something to do with that
redneckcougarguy is offline
post #30 of 30 (permalink) Old 03-17-2005, 03:12 PM
MA Drag Race Team Coordinator
1MTNCAT's Avatar
I'm certainly with KD on this one.
Back in the day, the Ford used the C-4's, C-6's and FMX trannies. They had several versions of each for small and big block application.
They also had the 3 speed and 4 speed stick cars. At the time, automatic transmissions weren't as refined as today, were heavier and didn't provide the necessary torque or gear ratio's to help accelerate the vehicles as the stick did, nor could they handle in most cases the associated power and torque of the larger "Big Block" engines.
Since the advent of the OD trannies, and the subsequent internal changes on the newer and older ones, the automatics have certainly come a long way. The changes in converters, the newer gear ratio's, the better converter control and the fact that lock-up types are now in use have certainly benefited the automatic, much more than improvements to the manuals. They are continually improving on them even now with even 5 and 6 speed autos in the works and available these days.
For drag racing purposes, consistency, and durability being considered, the automatic generally far outmatches the Stick/manual car. What KD said is certainly true, you still stress the drivetrain with a high stall automatic, but not like dumping 5000 or higher rpm to a still driveline. The automatic at least does have some tension against it. Manuals can be set up to also run very consistently with clutchless trannies, adjustable clutches, synchronized shifts and such that are around now, but they really aren't considered a street driveable option in most circumstances. Synchronized manuals are now everywhere. Years ago they weren't. Then you still have to worry about clutches holding the power, pressure plates and thow out bearings going out, driver error, accurate shift points, etc etc. It can be done, but it is much harder to do.
Road racing I feel, would certainly be a bit more beneficial for the manual just due to the shift factor. That being the ability to suddenly choose the gear you need to be in for braking and accelerating. It is also more beneficial for the top end pull if that is necessary. That being said, the fun factor also comes in to play here for the average/ daily street use vehicle for those that so choose.
As for an all-around transmission, I think that "years ago", most would have agreed probably the Manual transmission. Today, I don't think that would be the case at all. And with the Electronic tuning abilities these days, the performance parts available and the ability to manually shift the newer ones, with or without the lock up, I believe the Automatics have it hands down. The gap has been narrowed for sure, and I personally believe the automatic has taken the performance lead.
Besides, I much more prefer to drive down the road these days with my hand on the GF's ****, rather than on the shifter. But then, thats my preference.
Just my .02 cents.
Steve
Nitrous 11.75 @ 114 MPH
1MTNCAT is offline
