Question about speedo Gear - TCCoA Forums
post #1 of 10 (permalink) Old 03-02-2005, 04:48 PM Thread Starter
Franky-5-Fingaz's Avatar
Send a message via AIM to Franky-5-Fingaz
Hey everybody, quick question, if i swap in 3.73's, i was reading the technical articles and it said you would need a speedo gear to correct the speedometer. if you had a chip or tuner couldntt that correct the speedo?? or would u still need a new gear to correct it?
CarDomain Bird My T-bird
4.6L V8..
.... a Couple little bolt-ons.
Franky-5-Fingaz is offline
post #2 of 10 (permalink) Old 03-02-2005, 04:59 PM
Carlover007's Avatar
You need the new gear to correct it, since the speedo is not electronic (err not controlled by the chip anyways).
Carlover007 is offline
post #3 of 10 (permalink) Old 03-02-2005, 05:03 PM Thread Starter
is the gear easy to get at and replace? could anybody give me directions on how to replace it?? and where i could buy it?
4.6L V8..
post #4 of 10 (permalink) Old 03-02-2005, 05:09 PM
I got mine from Steeda, but you should be able to get it through any Ford dealer. I believe you want the purple gear, which is part # D0OZ-B.
mercutio is offline
post #5 of 10 (permalink) Old 03-02-2005, 06:39 PM Thread Starter
thanks, and there is a differnt gear for each gear ratio right? 3.72, 3.55, 3.73, and so on....
4.6L V8..
post #6 of 10 (permalink) Old 03-02-2005, 07:05 PM
It takes about 5 minutes to change once you're under the car. It's located at the tailshaft of the transmission, and is held in with one bolt.
-Rod
post #7 of 10 (permalink) Old 03-03-2005, 09:34 AM
Umm...I thought the 4R70W dind't have speed gears........he is talking about a 97 TB.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #8 of 10 (permalink) Old 03-03-2005, 10:22 AM
rustyul's Avatar
The 4R70W does have speed gears.
Glen "RustyUL" Weldon
95 Thunderbird LX - 4.6
rustyul is offline
post #9 of 10 (permalink) Old 03-03-2005, 10:31 AM
Mybad......thought they eliminated them on the Electronic trannies. In that case, the output is an 8 spline/gear and will require a purple 21 tooth speedo gear i believe.
post #10 of 10 (permalink) Old 03-03-2005, 10:42 AM
Send a message via AIM to chrisnack
if you want to see the locatoin, check my transmission pictures sticky thread in this forum.. nice pic of it for you... one bolt to remove the gear
from a stock 3.27 to 3.73 gear change, you need the gear to correct yoru speedo, your EEC can compensate for the shift points up to 3.73's, anything more than 2 steps and you would need a chip or reburn so you wouldn't be hitting the rev limiter when you are goosing it
NSN Motorsports
http://www.nsnmotorsports.com
"Fordless" - But I do have alot of Mercon V laying around...
'96 Eagle Talon ESI
Parts ---> Dan Newman - Town & Country Ford - 800-847-2047
chrisnack is offline
