Gear Oil ????????????? - TCCoA Forums
post #1 of 5 (permalink) Old 03-03-2005, 09:58 AM Thread Starter
Maic's Avatar
Hi,my 8.8 is reddy for pick up,im just not shure wich oil to use ,is a 8.8 whit new Torson .Tx for reply.
MAIC
Maic.
Maic is offline
post #2 of 5 (permalink) Old 03-03-2005, 12:17 PM
MAIC
With a stock trak-Loc - I use Mobil 1 75w-90
I would ask the shop guy what to use for a Torson ?
LST MN-12 is offline
post #3 of 5 (permalink) Old 03-03-2005, 08:12 PM
Stolen from http://www.torsen.com/fsae/fsaefaqframes.htm
8. What should I use for lubrication?
A GL-4 or GL-5 gear oil is required by Torsen Type 1 units. This oil provides high-pressure additives needed to prevent the oil from breaking down under the extreme conditions generated by the tooth mesh. A 75W-90 is recommended, but higher or lower viscosities can be used if they meet GL-4 or GL-5 specification. Either synthetic or conventional oils can be used as well.
I seem to remember some production vehicle that came with a torsen and they kept exploding..hopefully thats fixed. Good luck with yours.
icantdrive55 is offline
post #4 of 5 (permalink) Old 03-07-2005, 06:27 PM Thread Starter
Maic's Avatar
Got it !!!!!!!!!!!
Tx a lot ...... MAIC
Maic.
Maic is offline
post #5 of 5 (permalink) Old 03-08-2005, 10:27 PM
I used the ford synthetic gear oil with the friction modifier.
thndrchiken is offline
